Not Supported Status
  • Shorty Guard
    • Oct 2004
    • 12
    I have a huge problem with [NOT SUPPORTED] status.
    Agent has ~1400 instrumets in configuration. On server all of them monitored and must be Active, but ~1000 become in status [NOT SUPPORTED]. There are no logging about not supported instruments in agent's log (level 4 - debug). It looks like server set [NOT SUPPORTED] even not querying agent.
    version 1.0
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Is it number of user-defined parameters? Currently, ZABBIX v1.0 supports no more than 512 parameters, including approximately 450 user parameters.
    In order to increase this, do the following change in common.h:
    #define AGENT_MAX_USER_COMMANDS 2048 // or any other number
    ZABBIX v1.1 agent will be free of this limit.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Shorty Guard
      • Oct 2004
      • 12
      Thank you.
