Actions??? ZABBIX 1.1beta12
  • rondeniable
    • Jun 2006
    • 14
    Ok, Im running: ZABBIX 1.1beta12
    So i have been racking my brain with actions and not having any luck. It just is not working. Below are some config details.
    I have a media type setup:
    Description Email Media
    Type email
    SMTP server mail.gamewatch.com
    SMTP helo mail.gamewatch
    SMTP email [email protected]
    Admin user has email address assigned: [email protected]
    I have created a trigger:
    {Host.Linux:tcp,25.last(0)}=0
    On hosts where there is no smtp daemon listening the trigger seems to be in 0 state. So the trigger looks to be working.
    I created an action:
    Action type Send Message
    Source trigger
    Conditions Trigger severity = "High"
    Send message to Single User
    User Admin
    Repeat Repeat
    Number of repeats 5
    Delay between repeats 600
    Status enabled
    I swear i have made a thousand config changes and given that there were problems in the last couple beta versions with actions i thought that there may be a bug but it is in the change as fixed in this version.
    If anyone could help me though this i would so be thankfull, ive prob spent 20 hours on this alone.
    Please help!!
  • rondeniable
    • Jun 2006
    • 14
    Thanks for the reply.
    I tried that and the triggers still seem to be working as the trigger is showing as true where the port 25 is not listening.
    But still no action?? Seems it is the actions that is not working.. triggers seem to be fine.
    • rondeniable
      • Jun 2006
      • 14
      You know, When i look at the status of triggers page i see the triggers set to true and show actions i can see the action hitting... the weird part is that no mail is sent..
      What method does zabbix use to send a mail? Is there something that i need installed or configured? I have sendmail on the box.
      • rondeniable
        • Jun 2006
        • 14
        Looks like there is a bug.
        Server log...
        [root@gw-app2 ~]# tail -50 /tmp/zabbix_server.log
        026185:20060604:223501 SQL [select max(clock) from alarms where triggerid=12791 and clock<1149286052]
        026185:20060604:223501 Executing query:select max(clock) from alarms where triggerid=12791 and clock<1149286052
        026185:20060604:223501 SQL [select value from alarms where triggerid=12791 and clock=1149285480]
        026185:20060604:223501 Executing query:select value from alarms where triggerid=12791 and clock=1149285480
        026185:20060604:223501 In add_alarm(12791,0,0)
        026185:20060604:223501 In latest_alarm()
        026185:20060604:223501 SQL [select value from alarms where triggerid=12791 order by clock desc]
        026185:20060604:223501 Executing query:select value from alarms where triggerid=12791 order by clock desc
        026185:20060604:223501 Executing query:insert into alarms(triggerid,clock,value) values(12791,1149478501,0)
        026185:20060604:223501 In DBinsert_id()
        026185:20060604:223501 Executing query:update alerts set retries=3,error='Trigger changed its status. WIll not send repeats.' where triggerid=12791 and repeats>0 and status=0
        026185:20060604:223501 End of add_alarm()
        026185:20060604:223501 Executing query:update triggers set value=0,lastchange=1149478501,error='' where triggerid=12791
        026185:20060604:223501 In update_trigger_value. Before apply_actions. Triggerid [12791]
        026185:20060604:223501 In apply_actions(triggerid:12791,alarmid:221,trigger_ value:0)
        026185:20060604:223501 Applying actions
        026185:20060604:223501 Executing query:select actionid,userid,delay,subject,message,recipient,ma xrepeats,repeatdelay,scripts,actiontype from actions where nextcheck<=1149478501 and status=0
        026185:20060604:223501 Query::select actionid,userid,delay,subject,message,recipient,ma xrepeats,repeatdelay,scripts,actiontype from actions where nextcheck<=1149478501 and status=0
        026185:20060604:223501 Query failed:Unknown column 'delay' in 'field list' [1054]
        026174:20060604:223501 One server process died. Shutting down...
        026174:20060604:223501 0. Killing PID=[26176]
        026174:20060604:223501 1. Killing PID=[26178]
        026174:20060604:223501 2. Killing PID=[26180]
        026182:20060604:223501 Server [4]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026174:20060604:223501 3. Killing PID=[26182]
        026183:20060604:223501 Server [5]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026174:20060604:223501 4. Killing PID=[26183]
        026184:20060604:223501 Server [6]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026174:20060604:223501 5. Killing PID=[26184]
        026174:20060604:223501 6. Killing PID=[26185]
        026174:20060604:223501 7. Killing PID=[26186]
        026174:20060604:223501 8. Killing PID=[26187]
        026174:20060604:223501 9. Killing PID=[26188]
        026174:20060604:223501 10. Killing PID=[26189]
        026174:20060604:223501 11. Killing PID=[26191]
        026174:20060604:223501 12. Killing PID=[26193]
        026174:20060604:223501 13. Killing PID=[26195]
        026174:20060604:223501 14. Killing PID=[26197]
        026176:20060604:223501 Server [1]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026178:20060604:223501 Server [2]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026180:20060604:223501 Server [3]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026186:20060604:223501 Server [8]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026187:20060604:223501 Server [9]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026188:20060604:223501 Server [10]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026189:20060604:223501 Server [11]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026191:20060604:223501 Server [12]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026193:20060604:223501 Server [13]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026195:20060604:223501 Server [14]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026197:20060604:223501 Server [15]. Got QUIT or INT or TERM or PIPE signal. Exiting...
        026174:20060604:223501 ZABBIX server is down.
        [root@gw-app2 ~]#
        In the beta12 patch it appears that the delay field was removed and it looks like something is still calling to that field.
        • rondeniable
          • Jun 2006
          • 14
          Upgraded to 1.1
          Corrected the server crashing issues, was a version issues.
          Still none of my actions are working. I upgraded the server and client with no luck as well.
          There has to be something im doing wrong here as i dont here anyone else complaining.
          Im going to try a complete rebuild of the database.
          • cva
            • Apr 2006
            Same Problem
            I seem to be having the same problem. I have played with Media settings, Action settings, and varying which Trigger I'm trying to report but, no matter what I try, my actions never come on.
            Looking through the log file, I never even see a line with the string "action" in it.
            I would love to debug this if someone could get me started where to look.
            (unfortunately I'm not sure anyone who can solve problems reads these things because I've yet to ever receive a reply to any of my posts)
            • cva
              • Apr 2006
              script action
              for what it's worth, i also setup a script media type just to make sure the problem isn't with my email configuration, and that doesn't work either.
              the script a 1 line bash script that logs when it was called.
              this is the only thing keeping from using zabbix in production, so I am really anxious to get this resolved.
              • rondeniable
                • Jun 2006
                • 14
                me to, i have like 60 nodes i want to use this in and this actions thing ive been looking at for months now.
                Im about to give up actually.
                • cnienhaus
                  • Jun 2006
                  Actions???
                  Has anyone been able to get this working on any system Linux or Win32? Has anyone been able to get any kind of message to notify a trigger condition change. I really would like to use this to replace Nagios, but without notifications its just another pretty gui.
                  • Aaron
                    • May 2006
                    • 16
                    I have been having the same problem. I have been fiddling with this for a couple hours and this thread is the forst one I found when I started searching the forums. The first version I ever tried was 1.1beta9 (on 1.1 stable now) so I am a new user and I can't rule out that I am doing something wrong.
                    • Aaron
                      • May 2006
                      • 16
                      I finally figured this out this morning. I would call this a bug, but I would be happy if it was just better documented or if the config tabs involved were more obvious somehow.
                      I have tried redefining triggers and actions in all sorts fo different ways and ultimately, none worked. If you look at the actions tab, there are none listed, even though there should be many.
                      I just configued the "Email" media for one of my users and now the actions appear to be working. There are several check boxes for severity listed. I checked all of them. My current assumption is that if you don't check the box for severity "Warning" then no trigger with that severity will send you an e-mail.
                      I had falsely assumed that a action would be triggered even though the user was not properly defined. It appears this is not the case. If your user does not have the media type "Email" defined with the proper severity boxes checked, I think you get NOTHING. The individual user's media config tab appears on the far right of the users tab. It is on the same line, each user will have the word "media" listed and it is clickable. I really wish that was more obvious...
                      Anyway, quirky behaviour, but it is working for me now.
                      • elkor
                        • Jul 2005
                        • 299
                        How else would zabbix know where to send the email.......
                        (an error message in the server log would have been nice though, did you have the log level set at full verbosity?)
                        • rondeniable
                          • Jun 2006
                          • 14
                          Fixed?
                          As stated above in my original post you can see where i had the email type. That was not my problem.
                          After prob about 10 hours of troubleshooting this i completly dropped my database and reimported a fresh 1.1 copy, and reconfigured everything.
                          Once i did that everything works.
                          Now, while i could have had something configured improperly, the amount of times i looked at this im not sure that there could have been a config error.
                          Im guessing, that my config changes along with the upgrade process did something that my system did not like.
                          I did have the server daemon in verbose, and after sorting though the miles of data i was not able to find anything.
                          • cva
                            • Apr 2006
                            flushing?
                            Oh well, I kinda figured flushing the database and starting over may be my only recourse, but I was hoping I could avoid that.
                            I guess I'll try it this evening (my carefully constructed configuration be damned!) and post the results.
                            cva
                            • cva
                              • Apr 2006
                              fixed.
                              dropping and recreating the database (using the 1.1-final schema and data) resulted in working actions.
                              go figure.
                              just hope I don't have to do this again...
