In 2.0.2. if there are triggers dependent on other triggers and they are hit during a maintenance window, then as expected they are not shown, but the dependent triggers are immediately after the maintenance window ends.
For example, the trigger:
Zabbix agent on {HOSTNAME} is unreachable for 10 minutes
Depends on :
Zabbix alerter processes more than 75% busy
During the maintenance window the Zabbix alerter process will be more than 75% busy and no alert is fired as expected. But when the maintenance window ends, the alarm for the Zabbix agent trigger will be raised up as PROBLEM and 1 minute later cleaned up with OK.
I suspect this is a bug, please confirm it.
Regards, s0r1n
Depends on :
Regards, s0r1n
