Windows agent 2.0.4 not reachable
  • rhanthony
    • Feb 2013
    I've done some searching around here and the rest of the internet so I'm pretty sure I'm not missing any of the usual suspects.
    I have a Zabbix server installed on CentOS 6 (v 1.8.16), and 2 windows boxes that have the 2.0.4 agent installed and running as a service. One is a Win 7 pro box, and that works just fine.
    The other is a Win 2008 R2, and despite the service being started and showing in netstat that it is indeed LISTENING on 10050, and a firewall rule for permit,tcp,any,any put in for the zabbix_agentd executable... the server continues to show it as unreachable.
    I have also stopped the agent service for 10 minutes, and then restarted, without any improvement.
    I did notice that the latest data time stamp hadn't been updating in the past hour or so as well so...
    I have also deleted the host in the Zabbix server, and rebuilt it, and it has the same issue. The time stamp did update to current however.
    I'm at a total loss here. Is there some huge difference between Win 7 and Win 2008 R2 as far as the agent is concerned? They're both x64 and I used the proper agent .exe's for them (same one).
    Same config file as well (zabbix log file and server ip are only changes from default).
  • tchjts1
    • May 2008
    • 1605
    See if this thread provides any help:
