I first started having problems with the beta12, the server was crashing on me at random times. I was having no problem from beta9 until beta 12. Now that I see the 1.1 has been released I thought maybe that would fix the problem so I upgraded to it, but it shuts down after you start it up. I turned on the highest level of debugging and below is last chunk of the resulting log file.. (if you need more of it, let me know I can try to post more.. it's apparently a little over the size limit of what can be posted on here.) if anyone can help me figure out what is going on, or what else to do to troubleshoot this, I'd appreciate it.
Thanks,
014902:20060602:143400 RESULT_STR [Ð]
014902:20060602:143400 In process_new_value()
014902:20060602:143400 In add_history(system.cpu.load[,avg15],,0,2)
014902:20060602:143400 In add_history(18099,DOUBLE:1.805556)
014902:20060602:143400 In add_history()
014902:20060602:143400 Executing query:insert into history (clock,itemid,value) values (1149284040,18099,1.805556)
014902:20060602:143400 In add_trend()
014902:20060602:143400 SQL [select num,value_min,value_avg,value_max from trends where itemid=18099 and clock=1149282000]
014902:20060602:143400 Executing query:select num,value_min,value_avg,value_max from trends where itemid=18099 and clock=1149282000
014902:20060602:143400 Executing query:update trends set num=2, value_min=1.805556, value_avg=2.091128, value_max=2.376700 where itemid=18099 and clock=1149282000
014902:20060602:143400 End of add_history
014902:20060602:143400 In update_item()
014902:20060602:143400 Executing query:update items set nextcheck=1149284700,prevvalue=lastvalue,lastvalue ='1.805556',lastclock=1149284040 where itemid=18099
014902:20060602:143400 In update_functions(18099)
014902:20060602:143400 Executing query:select distinct function,parameter,itemid,lastvalue from functions where itemid=18099
014902:20060602:143400 In update_triggers [18099]
014902:20060602:143400 Executing query:select distinct t.triggerid,t.expression,t.status,t.dep_level,t.pr iority,t.value,t.description from triggers t,functions f,items i where i.status<>3 and i.itemid=f.itemid and t.status=0 and f.triggerid=t.triggerid and f.itemid=18099
014902:20060602:143400 End of update_triggers [18099]
014902:20060602:143400 GOT VALUE TYPE [0x0]
014902:20060602:143400 get_value_agent: host[Calypso] ip[10.2.1.92] key [system.cpu.load[,avg15]]
014902:20060602:143400 Sending [system.cpu.load[,avg15]
014902:20060602:143400 In add_history(18105,DOUBLE:0.133333)
014902:20060602:143400 Executing query:insert into history (clock,itemid,value) values (1149284040,18105,0.133333)
014899:20060602:143401 Update IP [10.28.1.1 is alive (1738 ms)]
014899:20060602:143401 Mseconds [1738.000000]
014899:20060602:143401 IP [10.28.1.1] alive [1]
014899:20060602:143401 In process_value([email protected])
014899:20060602:143401 In process_ip([10.28.1.1])
014899:20060602:143401 End of process_ip([0])
014899:20060602:143401 SQL [select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h .useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.va lue_type,i.trapper_hosts,i.delta,i.units,i.multipl ier,i.formula from items i,hosts h where h.status=0 and h.hostid=i.hostid and h.ip='10.28.1.1' and i.key_='icmpping' and i.status=0 and i.type=3]
014899:20060602:143401 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h .useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.va lue_type,i.trapper_hosts,i.delta,i.units,i.multipl ier,i.formula from items i,hosts h where h.status=0 and h.hostid=i.hostid and h.ip='10.28.1.1' and i.key_='icmpping' and i.status=0 and i.type=3
014903:20060602:143401 After accept()
014903:20060602:143401 Before read()
014903:20060602:143401 After read() 2 [104]
014903:20060602:143401 Got line:<req><host>YXViMTA0</host><key>RXZlbnRsb2dbU3lzdGVtXQ==</key><data>WkJYX05PVFNVUFBPUlRFRAo=</data></req
014903:20060602:143401 Trapper got [<req><host>YXViMTA0</host><key>RXZlbnRsb2dbU3lzdGVtXQ==</key><data>WkJYX05PVFNVUFBPUlRFRAo=</data></req]
014903:20060602:143401 XML received [<req><host>YXViMTA0</host><key>RXZlbnRsb2dbU3lzdGVtXQ==</key><data>WkJYX05PVFNVUFBPUlRFRAo=</data></req]
014903:20060602:143401 In process_data([aub104],[Eventlog[System]],[ZBX_NOTSUPPORTED
014903:20060602:143401 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h .useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.ho stid,h.status,i.value_type,h.errors_from,i.snmp_po rt,i.delta,i.prevorgvalue,i.lastclock,i.units,i.mu ltiplier,i.snmpv3_securityname,i.snmpv3_securityle vel,i.snmpv3_authpassphrase,i.snmpv3_privpassphras e,i.formula,h.available,i.status,i.trapper_hosts,i .logtimefmt,i.valuemapid from hosts h, items i where h.status=0 and h.hostid=i.hostid and h.host='aub104' and i.key_='Eventlog[System]' and i.status=0 and i.type in (2,7)
014903:20060602:143401 In check_security()
014903:20060602:143401 Processing [ZBX_NOTSUPPORTED
014903:20060602:143401 In process_new_value()
014903:20060602:143401 In add_history(Eventlog[System],,2,4)
014903:20060602:143401 In add_history(19185,STRING:ZBX_NOTSUPPORTED
014903:20060602:143401 In add_history_log()
014893:20060602:143401 One server process died. Shutting down...
014893:20060602:143401 0. Killing PID=[14895]
014893:20060602:143401 1. Killing PID=[14896]
014893:20060602:143401 2. Killing PID=[14899]
014893:20060602:143401 3. Killing PID=[14901]
014893:20060602:143401 4. Killing PID=[14902]
014893:20060602:143401 5. Killing PID=[14903]
014893:20060602:143401 6. Killing PID=[14905]
014893:20060602:143401 7. Killing PID=[14907]
014893:20060602:143401 8. Killing PID=[14909]
014893:20060602:143401 9. Killing PID=[14911]
014893:20060602:143401 ZABBIX server is down.
014895:20060602:143401 Server [1]. Got QUIT or INT or TERM or PIPE signal. Exiting...
014896:20060602:143401 Server [2]. Got QUIT or INT or TERM or PIPE signal. Exiting...
014905:20060602:143401 Server [7]. Got QUIT or INT or TERM or PIPE signal. Exiting...
014907:20060602:143401 Server [8]. Got QUIT or INT or TERM or PIPE signal. Exiting...
014911:20060602:143401 Server [10]. Got QUIT or INT or TERM or PIPE signal. Exiting...
014901:20060602:143401 Server [4]. Got QUIT or INT or TERM or PIPE signal. Exiting...
014899:20060602:143401 Server [3]. Got QUIT or INT or TERM or PIPE signal. Exiting...
014902:20060602:143401 Server [5]. Got QUIT or INT or TERM or PIPE signal. Exiting...
014909:20060602:143401 Server [9]. Got QUIT or INT or TERM or PIPE signal. Exiting...
Thanks,
