Zabbix 2.0.5 on Ubuntu 12.04.2 problem
  • sitetroniq
    • Feb 2013
    Hi
    Im trying to setup Zabbix 2.0.5 on Ubuntu Server 12.04.2 (amd64).
    I have followed the installation guide at: http://library.linode.com/server-mon...install-zabbix.
    I've started zabbix_server and zabbix_agent deamon (status: running) , but when i access the php frontend it says that zabbix_server on TCP 10051 is not running.
    When i do:
    netstat -tln
    Active Internet connections (only servers)
    Proto Recv-Q Send-Q Local Address Foreign Address State
    tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN
    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
    tcp 0 0 0.0.0.0:10050 0.0.0.0:* LISTEN
    tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN
    tcp6 0 0 :::22 :::* LISTEN
    The tcp/10051 port is not open???
    I have added the zabbix TCP/UDP ports in /etc/services and rebooted.
    Any ideas ?
    Kindly, Robert
  • SamSeriously
    • Mar 2013
    Hey Robert,
    I have the same problems as you, same operating system.
    I hope to get some help ... but I saw you already got redirected from the support site however without any proper help.
    Maybe you got any further already?
    2.0.4 worked without any problem on the same system.
    • SamSeriously
      • Mar 2013
      Hey Robert,
      adding the mysql password password in:
      /usr/local/etc/zabbix_server.conf
      helped for me.
      It's marked as not mandatory, but apperently it is mandatory if your mysql server has a password set (which it normally always has).
      After adding and restarting everything is working as expected.
      Regards,
      Sam
