TimeTicks data being ignored
  • adg
    • Sep 2012
    • 17
    Hi All,
    Trying to pass a time value back, but it fails, and is not sent to the server. Tried various options server side, including just accepting it as a text value - to no avail.
    Only happens with time value, single numbers are returned OK.
    Based on the APC template from Zabbix Wiki.
    Log is below:
    4712:20130221:150438.596 For key [apc[.1.3.6.1.4.1.318.1.1.1.2.1.2.0]] received value [0:00:00.00]
    4712:20130221:150438.599 In process_value() key:'UPStest.ignoreme.test:apc[.1.3.6.1.4.1.318.1.1.1.2.1.2.0]' value:'0:00:00.00'
    4712:20130221:150438.602 In send_buffer() host:'ourserver.ourdomain.com' port:10051 values:0/100
    4712:20130221:150438.605 End of send_buffer():SUCCEED
    4712:20130221:150438.608 buffer: new element 0
    4712:20130221:150438.611 End of process_value():SUCCEED
    4712:20130221:150438.614 End of process_active_checks()
    4712:20130221:150438.617 In get_min_nextcheck()
    4712:20130221:150438.620 Sleeping for 1 second(s)
    3972:20130221:150438.726 In collect_perfstat()
    4712:20130221:150439.624 In send_buffer() host:'ourserver.ourdomain.com' port:10051 values:1/100
    4712:20130221:150439.632 JSON before sending [{
    "request":"agent data",
    "data":[
    "host":"UPStest.ignoreme.test,
    "key":"apc[.1.3.6.1.4.1.318.1.1.1.2.1.2.0]",
    "value":"0:00:00.00",
    "clock":1361459078,
    "ns":416752938}],
    "clock":1361459079,
    "ns":433698046}]
    4712:20130221:150439.642 JSON back [{
    "response":"success",
    "info":"Processed 0 Failed 1 Total 1 Seconds spent 0.000069"}]
    4712:20130221:150439.647 In check_response() response:'{
    "info":"Processed 0 Failed 1 Total 1 Seconds spent 0.000069"}'
    4712:20130221:150439.651 Info from server: Processed 0 Failed 1 Total 1 Seconds spent 0.000069
    4712:20130221:150439.656 End of check_response():SUCCEED
    4712:20130221:150439.661 OK
    4712:20130221:150439.665 End of send_buffer():SUCCEED
    4712:20130221:150439.670 Sleeping for 1 second(s)
    Any thoughts?
