agentless ZABBIX installation
  • mauser
    • Jun 2006
    Hi all,
    I have successfully installed zabbix on my openbsd box and everything went ok. but i am having problem:
    I just want to monitor a pop3 server and a smtp server. these servers are out of my control, so i cannot install agents on them. but i know that zabbix supports the basic checks, like ping, pop, smtp and others. my question is how can i add these hosts using the web interface. should i add them as hosts or as items...? i can't understand the principle of adding monitored servers. i would be happy if someone could write me step-by-step how to add a pop3 server to be monitored
    thanks in advance
  • schneck
    • May 2006
    • 62
    Re: agentless ZABBIX installation
    Add host entries for your SMTP and POP3 servers.
    Then add simple checks in items for the hosts.
    \B.
