mysql -u root zabbix < schema.sql
ERROR 1064 (42000) at line 384: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'mediaid int(4) NOT NULL auto_increment,
userid int(4) DEFAULT '0' NOT NULL,
' at line 2
' at line 2
