SNMP item with dynamic indexes fail
  • lukeiam
    • Sep 2012
    • 38
    I wanted to ask if this bug is still present:
    As per the feedback, this issue is still experienced in newer releases.
    I am running 2.0.5 on CentOS 5U8
    Using:
    IP-MIB::ipAdEntAddr["index","IP-MIB::ipAdEntAddr","IpAddress"]
    Returns NOT FOUND error.
    snmpwalk -v 2c -c public x.x.x.x ipAdEntAddr
    IP-MIB::ipAdEntAddr.x.x.x.x = IpAddress: x.x.x.x
    Thank you for your help,
    Regards,
    Luke
  • Colttt
    • Mar 2009
    • 878
    its not clodes, also the bug still exist
    Debian-User
    Sorry for my bad english
    • lukeiam
      • Sep 2012
      • 38
      Thank you for the follow up.
      How can I report to this bug to put some focus on it?
      I would like it resolved in a future release.
      Of course I am willing to provide more information on the problem if needed.
      Regards,
      Luke
      • lukeiam
        • Sep 2012
        • 38
        Unfortunately I do not know how to re-open that bug or get more visibility on it.
        My current workaround is:
        In zabbix_agentd.conf I added:
        UserParameter=public.ip,snmpwalk -v 2c -c public -On 192.168.1.1 ipAdEntAddr | grep -v "IpAddress: 127" | grep -v "IpAddress: 169" | grep -v "IpAddress: 192" | awk '{print $4}'
        I created an item in zabbix and trigger for it which flags if the IP changes.
        Regards,
        Luke
        • CeeEss
          • Nov 2007
          • 103
          Same here. Just noticed it today when i went to check port usage on our biggish HP switch - no data for any index-based SNMP items. Running v2.0.7 (revision 37436) (31 July 2013)
          • CeeEss
            • Nov 2007
            • 103
            Deleted template linkage(s) and relinked - all good now.
