Log File Monitoring
  • kamaleshwaran86
    • Mar 2013
    Log File Monitoring
    Hi All,
    I tried to monitor catalina.out file of tomcat process in redhat linux OS. When i try to stop tomcat process, I could able to see the trigger status as PROBLEM. But, when I started the process, trigger still remain PROBLEM status instead of changing to OK status.
    My trigger expression: {RHEL.gogoib:log["/usr/local/apache-tomcat-6.0.35/logs/catalina.out","Stopping","UTF-8",1].str(Stopping)}=1
    I also tried with below expression, but still experience the same problem.
    {RHEL.gogoib:log["/usr/local/apache-tomcat-6.0.35/logs/catalina.out","Stopping","UTF-8",1].logsource(stopping)}=0
    Please someone help on this.
    Thanks,
    Kamal
  • BDiE8VNy
    • Apr 2010
    • 680
    The trigger function str(Stopping) evaluates to 1 when the last received value of the corresponding item includes the string 'Stopping'.
    So far so good.
    But the corresponding item key:
    lets the agent send only lines containing 'Stopping' to the server.
    The trigger will always evaluate to 1, because the item will never get a log line without containing 'Stopping'.
