Brand new to Zabbit, was trying to install it on my CENTOS 5.9 x86_64 server, by following the instructions, however when i run yum install zabbix-server-mysql zabbix-web-mysql, I get bunch of errors:
zabbix-server-mysql-2.0.5-1.el5.x86_64 from zabbix has depsolving problems
--> Missing Dependency: libmysqlclient.so.15(libmysqlclient_15)(64bit) is needed by package zabbix-server-mysql-2.0.5-1.el5.x86_64 (zabbix)
zabbix-web-mysql-2.0.5-1.el5.x86_64 from zabbix has depsolving problems
--> Missing Dependency: php-mysql is needed by package zabbix-web-mysql-2.0.5-1.el5.x86_64 (zabbix)
zabbix-web-2.0.5-1.el5.x86_64 from zabbix has depsolving problems
--> Missing Dependency: httpd is needed by package zabbix-web-2.0.5-1.el5.x86_64 (zabbix)
--> Missing Dependency: php >= 5.0 is needed by package zabbix-web-2.0.5-1.el5.x86_64 (zabbix)
--> Missing Dependency: libmysqlclient.so.15()(64bit) is needed by package zabbix-server-mysql-2.0.5-1.el5.x86_64 (zabbix)
--> Missing Dependency: php-gd is needed by package zabbix-web-2.0.5-1.el5.x86_64 (zabbix)
--> Missing Dependency: php-mbstring is needed by package zabbix-web-2.0.5-1.el5.x86_64 (zabbix)
--> Missing Dependency: php-bcmath is needed by package zabbix-web-2.0.5-1.el5.x86_64 (zabbix)
--> Missing Dependency: php-xml is needed by package zabbix-web-2.0.5-1.el5.x86_64 (zabbix)
Error: Missing Dependency: libmysqlclient.so.15()(64bit) is needed by package zabbix-server-mysql-2.0.5-1.el5.x86_64 (zabbix)
Error: Missing Dependency: httpd is needed by package zabbix-web-2.0.5-1.el5.x86_64 (zabbix)
Error: Missing Dependency: php-bcmath is needed by package zabbix-web-2.0.5-1.el5.x86_64 (zabbix)
Error: Missing Dependency: php-gd is needed by package zabbix-web-2.0.5-1.el5.x86_64 (zabbix)
Error: Missing Dependency: php-mbstring is needed by package zabbix-web-2.0.5-1.el5.x86_64 (zabbix)
Error: Missing Dependency: php-mysql is needed by package zabbix-web-mysql-2.0.5-1.el5.x86_64 (zabbix)
Error: Missing Dependency: php-xml is needed by package zabbix-web-2.0.5-1.el5.x86_64 (zabbix)
Error: Missing Dependency: php >= 5.0 is needed by package zabbix-web-2.0.5-1.el5.x86_64 (zabbix)
Error: Missing Dependency: libmysqlclient.so.15(libmysqlclient_15)(64bit) is needed by package zabbix-server-mysql-2.0.5-1.el5.x86_64 (zabbix)
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
Obviously I'm missing something, but can't figure it out.. Anyone can show me the correct way to install it, kind of dummy guide ? ..
Thx
Thx
