zabbix1.1 .str() in trigger exp does not allow spaces
  • dcrandall
    • Apr 2006
    • 59
    I just discovered that if you are using .str() in a trigger expression, you cannot use a string that contains spaces. i.e {my.host:my.key.str(My String)}=0 does not work.
    Just an FYI.
  • Ismael Medina
    • Mar 2007
    • 15
    Problem with STR function
    , i have a trigger that sould works with this expression.
    {win-icompapp:forecastonly.str(READY)}=1
    but it doesn't, if I use the expression below it works.
    {win-icompapp:forecastonly.str(/)}=1
    why????, I has been working on it without results, the lates data is:
    Estatus: READY, Ultima Ejecucion: 3/5/2007 0:01:01 Archivo: ForecastOnly070503-000105.log Modificado: 03/05/2007 07:14
    Could you help me.
    thanks in advance.
