Finding Zabbix server application template
  • hmeftah
    • Mar 2013
    • 10
    Hi All,
    I've upgraded Zabbix 1.8.1 to Zabbix 2.0.5 on Ubuntu 10.04. But I can't find the Zabbix Server application template which is there on a recent Fedora package I installed on my personal laptop.
    Where can I find this App? How to install it?
    The graph displayed by this App (on my fedora version) are different ( bold line and degraded color) from the ones I have on my Ubuntu version why that? Do I have tweak my ubuntu settings or zabbix settings?
  • heaje
    • Sep 2009
    • 325
    You don't have it in your old installation after the upgrade because the templates for each version are only put in place after a brand-new install (it's a part of applying the SQL files to the database in a new install). If you want the new template in an old installation, export it from a new installation using the web interface in "Configuration"->"Templates", click the checkbox for the template, then go to the combo box at the bottom of the page and select "Export" and click OK.
    After exporting the template, import it into your old install using the web interface there.
