since 3 Month we are working with Zabbix and every thing is fine. To keep the server as small as possible i like to use the Agent active, the config file works every thing is fine but today I notice that the Agent sends the same data twice.
I have no idea why. Mabey someone have the same problem or know the answer for my problem.
Picture of the plain text is appended.
Greetings
Sententiosus
--------------------------Edit-------------------------------
Problem Solved
Two IP Adress in die Agent config file (Server Add)
Greetings
Sententiosus
Problem Solved
