I'm trying to set up Zabbix 2.0.5 on CentOS 6.3 with Postgres database. Whole installation process went ok (I was following the documentation), the only problem I've encountered is that during installing WEB frontend instalation wizard couldn't copy configuration file automatically (I had to copy it manually to www directory on server).
Problem is that, I can log in to zabbix only as a guest (no error messages in that state). While trying to log in as different user (default admininstrator account + manualiy created user in postgres), I'm just receiving message:
'Login name or password is incorrect' and nothing happen. Apache, postgres and zabbix_server services are running.
I'm not very experienced in managing systems and probably solution is one of the obvious ones, but so far I couldn't find any or I'm jut too dump to notice it.
Is there anyone who had similar problem? What could I possibly check / change? If there is anything I could add to help you help me, please, let me know.
Thanks a lot in advance
Jacek
Jacek
