I have a couple of graphs that continue to show no data (icmppingsec and smtp_perf). Other graphs seem to be working fine. When I look under latest data I can see that data is being collected. Any ideas?
I've noticed a similar problem. It affects my graphs of floating point data of simple_checks, but not integers. And old floating point items that I added before one of the upgrades seem to graph just fine still.
I haven't looked into it any deeper than this yet, graphs aren't all that important to my setup, but I would like to get a graph of the different ports on my switch.
I have the same issue. My hosts (Cisco routers) are getting the 'host ping' and 'WAN latency' (icmppingsec) items via the template, which means that the settings are equal to all systems. Two of my routers are getting all SNMP data, but no ICMP related data (host ping, icmppingsec). I can do a fping and ping from the console logged in as the Zabbix users to these systems, which works!! I have deleted them and recreated them.....still 'no data'. Anybody?
