web scenario check not connecting to server
  • ewag
    • Apr 2013
    Been asked to step in and administer a zabbix server that was installed by a previous consultant.
    They want multiple-step web scenario checks. I am having trouble getting zabbix to perform a simple google.com check.
    17029:20130419:131226.135 web scenario step "google there?:google test" error: error doing curl_easy_perform: Couldn't connect to server
    1st: I checked to see if libcurl was compiled. It showed "--with-libcurl" with the configure command in the history and I checked the server log to see if web monitoring was enabled.
    # grep WEB /var/log/zabbix/zabbix_server.log
     17007:20130419:123850.739 WEB monitoring:            YES
    2nd: We are sitting behind a proxy, so I checked to make sure curl could get out as both the zabbix and apache user. Worked fine.
    curl -x http://proxy.foo.bar:8080 http://www.google.com
    What else should I be checking? I made sure to include http_proxy=http://foor.bar:8080 in the variable section in the web scenario. I read that I should try a "make clean" and then reconfigure/ make install to "refresh" the zabbix install. And that I need to change the directory structure also during that process?
    Not sure I understand the rationale behind that. Could someone give me some pointers?
    Versions:
    Zabbix server v2.0.5 (revision 33558) (12 February 2013)
    Compilation time: Apr 3 2013 10:54:46
    curl 7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 NSS/3.13.6.0 zlib/1.2.3 libidn/1.18 libssh2/1.4.2
    CentOS release 6.4
