Hello everybody,
I am currently evaluating Zabbix in a lab environment and the experience I had so far is overwhelmingly positive. The documentation is excellent and the installation on CentOS v6 using Zabbix repositories was flawless for me. I started with version 2.0.5 and when 2.0.6 came out, I did an upgrade from the same repository, which also went just fine. However, following the upgrade, the Zabbix agent installed on the Zabbix server itself stopped sending updates. In Administration -> Queue screen, the Zabbix agent items were red and everything else was green, including Zabbix agent active. All other checks were working and updates were coming in (hardly surprising since they were coming from the localhost). I looked in the documentation and I've searched through the menus for a way of forcing some sort of update but without any luck. The last action I took before things came back to normal was to enable and disable the discovery but I don't know this is the trick that solved my problem since I haven't configured the discovery at all.
So here are my questions :
1 - Has anyone else experienced this kind of behavior ?
2 - What would be the best way to force the Zenoss server to contact the agent and ask for updates
