I was getting "doing curl_easy_perform: Timeout was reached" for a webcheck, but on the command line with curl it worked fine, taking about 2 secs.
Finally I restarted the zabbix server daemon, and now its fine.
v2.0.4
So it seems like a bug in the server to me.
Here more longs if it helps:
26172:20130503:114823.658 sleeping for 1 seconds
26192:20130503:114823.688 web scenario step "foo: bar" error: error doing curl_easy_perform: Timeout was reached
26192:20130503:114823.688 In process_step_data() rspcode:0 time:0.000000 speed:0.000000
26192:20130503:114823.688 query [txnlev:0] [select type,itemid from httpstepitem where httpstepid=57]
26192:20130503:114823.689 End of process_step_data()
26192:20130503:114823.689 query without transaction detected
26192:20130503:114823.689 query [txnlev:0] [update httptest set nextcheck=1367574503+delay where httptestid=30]
26170:20130503:114823.808 In get_pinger_hosts()
26170:20130503:114823.808 In DCconfig_get_poller_items() poller_type:3
26170:20130503:114823.808 End of DCconfig_get_poller_items():0
26170:20130503:114823.808 End of get_pinger_hosts():0
26170:20130503:114823.808 In process_pinger_hosts()
26170:20130503:114823.808 End of process_pinger_hosts()
26170:20130503:114823.808 icmp pinger #1 spent 0.000374 seconds while processing 0 items
26170:20130503:114823.808 In DCconfig_get_poller_nextcheck() poller_type:3
26170:20130503:114823.808 End of DCconfig_get_poller_nextcheck():1367574504
26170:20130503:114823.809 sleeping for 1 seconds
26214:20130503:114823.848 In collect_selfmon_stats()
26214:20130503:114823.848 End of collect_selfmon_stats()
Also a little question: when a webcheck is assigned to a client, it still runs on the server? The assignment makes no difference?
Regards,
Sean Boran
v2.0.4
Regards,
Sean Boran
