Errors in database creation
  • andy_dufresne
    • May 2013
    I am trying to install zabbix on a linux machine (with Oracle Enterprise Linux distribution 5.6). I get errors while executing the sql files to install an oracle schema. Here are the steps I followed
    1. Created a oracle schema with below sql
    create user zabbix identified by password;
    grant all privileges to zabbix;
    2. Executed the below command through sqlplus
    CREATE OR REPLACE DIRECTORY image_dir AS '/home/oracle/old_images'
    3. After I executed the below steps I got many errors
    sqlplus> set def off
    sqlplus> @database/oracle/schema.sql
    sqlplus> @database/oracle/images.sql
    Attached - DatabaseErrors.txt. I wasn't able to capture the complete list of errors since I executed it from command putty but the text file should give an idea.
    I am worried that the installation didn't go fine. How should I proceed?
  • Heilig
    • Mar 2013
    • 366
    Please, check database character set.
