Hi.
I'm desesperate.
My Zabbix server lost connections with all server each 4 or 6 hours.
It's a little installation.
I thonk aproblem whit mysql beacuse after restart work fine..
Logs show...
/etc/my.cnf
The number of server and item for monitoring it's not big...
I'm lost... apreciate help.
I'm desesperate.
Zabbix server is running Yes zabbix.tamainut.net:10051
Number of hosts (monitored/not monitored/templates) 77 38 / 12 / 27
Number of items (monitored/disabled/not supported) 7031 2491 / 56 / 4484
Number of triggers (enabled/disabled)[problem/unknown/ok] 1194 1194 / 0 [25 / 0 / 1169]
Number of users (online) 3 2
Required server performance, new values per second 30.35
Logs show...
11822:20130506:070756.790 [Z3005] query failed: [1317] Query execution was interrupted [insert into history (itemid,clock,value,ns) values ......
[mysqld] datadir=/var/lib/mysql socket=/var/lib/mysql/mysql.sock user=mysql max_connections=250 symbolic-links=0 #innodb_file_per_table = 1 thread_concurrency = 4 query_cache_size = 64M thread_cache_size = 8 myisam_sort_buffer_size = 64M read_rnd_buffer_size = 8M read_buffer_size = 2M sort_buffer_size = 2M table_cache = 512 max_allowed_packet = 1M key_buffer = 256M join_buffer_size = 256k innodb_buffer_pool_size = 3G innodb_lock_wait_timeout = 500 innodb_flush_method = O_DIRECT innodb_thread_concurrency = 4 [mysqld_safe] log-error=/var/log/mysqld.log pid-file=/var/run/mysqld/mysqld.pid
