API: how to get a trigger based on the expanded expression?
  • Mojah
    • Apr 2010
    • 60
    I'm using a query like this (simplified by zabbixapi in ruby):
    result = zbx.client.api_request(
          :method => "trigger.get",
          :params => {
            :filter => {
              :expression => "{13360}#0.2"
            :output => "extend",
            :expandExpression => true,
            :expandDescription => true,
    The above works, as I refer to the expression in the 'short' unexpanded version of '{13360}#0.2' where {13360} is the ID that refers to an item.
    However, I would like to use this way:
          :params => {
            :filter => {
              :expression => "{hostname:nginx.config_version.last(0)}#0.2"
    In the last example, the :expression contains the full expression that would also be visible in the WebUI. However, I can't find a way where this epxression filter would yield any results.
    Does anyone have any idea? Or is the :expression parameter only supporting the short, non-expanded, version?
  • Pavels
    • Oct 2011
    • 83
    There's currently no way to retrieve triggers by expanded expression. Filter parameters only accept values as they are stored in the database, and expressions are stored in a "compact" format.
