Front end shows "Zabbix server not running"
  • dbisdorf
    • May 2013
    I've just finished setting up Zabbix under Fedora 17, but the web front end is giving me the message "Zabbix server not running: the information displayed may not be current." This seems to suggest that the front end is unable to communicate with the Zabbix server, but I can't see why that would be. MySQL and the Zabbix server are definitely running, and they're at the location the server should be looking at.
    Can anyone suggest a course of investigation I can pursue?
    Here are the contents of my zabbix.conf.php file:
    <?php
    // Zabbix GUI configuration file
    global $DB;
    $DB['TYPE']     = 'MYSQL';
    $DB['SERVER']   = 'localhost';
    $DB['PORT']     = '3306';
    $DB['DATABASE'] = 'zabbix';
    $DB['USER']     = 'root';
    $DB['PASSWORD'] = '';
    // SCHEMA is relevant only for IBM_DB2 database
    $DB['SCHEMA'] = '';
    $ZBX_SERVER      = '127.0.0.1';
    $ZBX_SERVER_PORT = '10051';
    $ZBX_SERVER_NAME = 'CIM Test';
    $IMAGE_FORMAT_DEFAULT = IMAGE_FORMAT_PNG;
    Here's the results of "netstat -lnptu", showing that the Zabbix server and MySQL are running at the ports I've configured:
    Active Internet connections (only servers)
    Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
    tcp        0      0 0.0.0.0:10051           0.0.0.0:*               LISTEN      29721/zabbix_server
    tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      9482/mysqld
    I've tried using "localhost" instead of "127.0.0.1" in zabbix.conf.php to indicate the location of the Zabbix server, with the same results.
    Thanks,
    Don
  • f.koch
    • Feb 2010
    • 85
    how many trapper have you configured in your zabbix_server.conf? you need at least 1 , then the frontend won't complain.
    regards
    • dbisdorf
      • May 2013
      I believe I have 5 trappers configured. Here's the relevant section of my zabbix_server.conf:
      ### Option: StartTrappers
      #       Number of pre-forked instances of trappers.
      #       Trappers accept incoming connections from Zabbix sender, active agents, active proxies and child nodes.
      #       At least one trapper process must be running to display server availability in the frontend.
      # Mandatory: no
      # Range: 0-1000
      # Default:
      StartTrappers=5
      • tchjts1
        • May 2008
        • 1605
        Any pertinent entries in zabbix_server.log?
        • dbisdorf
          • May 2013
          Here's what my zabbix_server.log looks like after a clean start. The only thing that looks suspicious to me is the "unreachable poller" message given by server #8. Is this at all pertinent, and if so, what can I do to correct it?
           32579:20130507:092413.364 Starting Zabbix Server. Zabbix 2.0.6 (revision 35158).
           32579:20130507:092413.389 ****** Enabled features ******
           32579:20130507:092413.389 SNMP monitoring:           YES
           32579:20130507:092413.389 IPMI monitoring:            NO
           32579:20130507:092413.389 WEB monitoring:            YES
           32579:20130507:092413.389 Jabber notifications:       NO
           32579:20130507:092413.389 Ez Texting notifications:  YES
           32579:20130507:092413.389 ODBC:                       NO
           32579:20130507:092413.389 SSH2 support:              YES
           32579:20130507:092413.389 IPv6 support:              YES
           32579:20130507:092413.389 ******************************
           32583:20130507:092413.544 server #1 started [configuration syncer #1]
           32584:20130507:092413.545 server #2 started [db watchdog #1]
           32593:20130507:092414.059 server #9 started [trapper #1]
           32594:20130507:092414.064 server #10 started [trapper #2]
           32603:20130507:092414.128 server #18 started [http poller #1]
           32598:20130507:092414.117 server #13 started [trapper #5]
           32610:20130507:092414.324 server #22 started [history syncer #3]
           32600:20130507:092414.336 server #15 started [alerter #1]
           32614:20130507:092414.412 server #24 started [escalator #1]
           32615:20130507:092414.413 server #25 started [proxy poller #1]
           32613:20130507:092414.418 server #23 started [history syncer #4]
           32579:20130507:092414.418 server #0 started [main process]
           32599:20130507:092414.421 server #14 started [icmp pinger #1]
           32616:20130507:092414.421 server #26 started [self-monitoring #1]
           32602:20130507:092414.421 server #17 started [timer #1]
           32601:20130507:092414.444 server #16 started [housekeeper #1]
           32601:20130507:092414.444 executing housekeeper
           32609:20130507:092414.455 server #21 started [history syncer #2]
           32595:20130507:092414.324 server #11 started [trapper #3]
           32590:20130507:092414.576 server #6 started [poller #4]
           32608:20130507:092414.543 server #20 started [history syncer #1]
           32596:20130507:092414.594 server #12 started [trapper #4]
           32586:20130507:092414.627 server #3 started [poller #1]
           32601:20130507:092414.780 housekeeper deleted: 0 records from history and trends, 0 records of deleted items, 0 events, 0 alerts, 0 sessions
           32589:20130507:092414.843 server #5 started [poller #3]
           32588:20130507:092415.104 server #4 started [poller #2]
           32607:20130507:092415.143 server #19 started [discoverer #1]
           32591:20130507:092415.179 server #7 started [poller #5]
           32592:20130507:092415.204 server #8 started [unreachable poller #1]
          • f.koch
            • Feb 2010
            • 85
            do you use selinux?
            • tchjts1
              • May 2008
              • 1605
              That all looks normal.
              Any chance SElinux is enabled on your server? It has been known to cause some issues... You can run # getenforce to see the status
              (Edit) - LOL. f.koch and I had the same idea...
              • dbisdorf
                • May 2013
                Yes. If it helps, my /etc/selinux/config file looks like this:
                # This file controls the state of SELinux on the system.
                # SELINUX= can take one of these three values:
                #     enforcing - SELinux security policy is enforced.
                #     permissive - SELinux prints warnings instead of enforcing.
                #     disabled - No SELinux policy is loaded.
                SELINUX=enforcing
                # SELINUXTYPE= can take one of these two values:
                #     targeted - Targeted processes are protected,
                #     minimum - Modification of targeted policy. Only selected processes are protected.
                #     mls - Multi Level Security protection.
                SELINUXTYPE=targeted
                And my /etc/selinux/semanage.conf file looks like this:
                # Authors: Jason Tang <[email protected]>
                # Copyright (C) 2004-2005 Tresys Technology, LLC
                #  This library is free software; you can redistribute it and/or
                #  modify it under the terms of the GNU Lesser General Public
                #  License as published by the Free Software Foundation; either
                #  version 2.1 of the License, or (at your option) any later version.
                #  This library is distributed in the hope that it will be useful,
                #  but WITHOUT ANY WARRANTY; without even the implied warranty of
                #  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
                #  Lesser General Public License for more details.
                #  You should have received a copy of the GNU Lesser General Public
                #  License along with this library; if not, write to the Free Software
                #  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
                # Specify how libsemanage will interact with a SELinux policy manager.
                # The four options are:
                #  "source"     - libsemanage manipulates a source SELinux policy
                #  "direct"     - libsemanage will write directly to a module store.
                #  /foo/bar     - Write by way of a policy management server, whose
                #                 named socket is at /foo/bar.  The path must begin
                #                 with a '/'.
                #  foo.com:4242 - Establish a TCP connection to a remote policy
                #                 management server at foo.com.  If there is a colon
                #                 then the remainder is interpreted as a port number;
                #                 otherwise default to port 4242.
                module-store = direct
                # When generating the final linked and expanded policy, by default
                # semanage will set the policy version to POLICYDB_VERSION_MAX, as
                # given in <sepol/policydb.h>.  Change this setting if a different
                # version is necessary.
                #policy-version = 19
                # expand-check check neverallow rules when executing all semanage commands.
                # Large penalty in time if you turn this on.
                expand-check=0
                # usepasswd check tells semanage to scan all pass word records for home directories
                # and setup the labeling correctly.  If this is turned off, SELinux will label /home
                # correctly only.  You will need to use semanage fcontext command.
                # For example, if you had home dirs in /althome directory you would have to execute
                # semanage fcontext -a -e /home /althome
                usepasswd=False
                bzip-small=true
                bzip-blocksize=5
                ignoredirs=/root
                • dbisdorf
                  • May 2013
                  Output of "getenforce" confirms that selinux is turned on:
                  [root@monitor-test selinux]# getenforce
                  Enforcing
                  • tchjts1
                    • May 2008
                    • 1605
                    That could very well be your problem.
                    To temporarily disable it, you can run # setenforce Permissive
                    • Alan
                      • Aug 2010
                      • 12
                      Try the followings commands :
                      semanage port -a -t http_port_t -p tcp 10051
                      setsebool httpd_can_network_connect=1
                      It works for me
                      Alan
                      • dbisdorf
                        • May 2013
                        Yes, disabling selinux did seem to allow the front end to communicate with the Zabbix server.
                        In the long term, and in a production environment, I would not want to have selinux turned off. Can you suggest what changes I would need to make in order to prevent selinux from blocking this particular communication?
                        EDIT: Alan responded just as I was typing this post. I'll try his settings, unless any other settings would be more appropriate.
                        Thanks to everyone who responded!
                        • dbisdorf
                          • May 2013
                          On my machine, running the setsebool command suggested by Alan was sufficient to get the front end to see the server:
                          I could not, however, run the suggested semanage command, nor did it appear to be necessary. Port 10051 was already defined in semanage as a zabbix port:
                          [root@monitor-test selinux]# semanage port -l |grep 10051
                          zabbix_port_t                  tcp      10051
                          And I could not redefine it:
                          [root@monitor-test selinux]# semanage port -a -t http_port_t -p tcp 10051
                          /sbin/semanage: Port tcp/10051 already defined
                          But since the front end seems to work fine without defining port 10051 as an httpd port, I think this command is unnecessary. In any case, wouldn't this semanage command allow httpd to listen to 10051? Which seems wrong to me; I think the front end needs to send to 10051, while the zabbix server needs to listen to 10051, which is how I believe my system is currently configured, based on the output of semanage.
                          • trikke76
                            • Apr 2013
                            • 42
                            don't forget to add the -P option to setsebool
                            else u will lose the configuration after your reboot
                            setsebool -P httpd_can_network_connect on
                            normally it should be enough to run this line and only give access to port 10051
                            if u still get the error that te server is not running check if the server is running
                            chkconfig zabbix-server status
                            • dbisdorf
                              • May 2013
                              Yes, I found out about the -P option for setsebool the hard way. Everything on my test server seems to be working correctly now. As I mentioned previously, I didn't need to run "semanage port -a -t http_port_t -p tcp 10051"; I assume some other part of the setup process had defined this zabbix port already.
