Web Monitoring not working
  • catchvjay
    • May 2013
    • 12
    Hi Friends,
    I am trying to setup web monitoring in zabbix 2.0.6 as per zabbix documentation with real time scenario. I have set it up exactly same way as described in doc but i am receiving error in first step " Error: Required pattern not found". Can anyone tell me how to trouble shoot this kind of errors?
    I have created steps as per https://www.zabbix.com/documentation..._life_scenario.
    Thanks in advance for your time.
    Regards,
    Vijay
  • tchjts1
    • May 2008
    • 1605
    These are the steps I use for the simple Zabbix frontend check.
    The only thing painted out is the IP of my Zabbix server.
    Maybe this will help.
    • catchvjay
      • May 2013
      • 12
      Thanks for your time. The only difference i see with mine is you have specified port number in the URLs. Do we need to specify port numbers in urls? While accessing zabbix i don't specify port number in URL.
      Regards,
      Vijay
      • tchjts1
        • May 2008
        • 1605
        I think you would only have to use port number if you have a virtual host set up... which we do.
        Do you have the "scenario" section set up like this?
        • catchvjay
          • May 2013
          • 12
          After removing matched pattern i am able to setup web monitoring properly. Is there anyway i can get "Required String" field from the webpage in case of setting rule for it?
          Regards,
          Vijay
          • Heilig
            • Mar 2013
            • 366
            Please show configuration for scenario and step 1, so it will be easier to tell what the problem is.
            • catchvjay
              • May 2013
              • 12
              Here is Scenario and step 1 from my web monitoring.
              • Heilig
                • Mar 2013
                • 366
                Hmm, the settings is correct. Do I understand correctly that the error occurs when you add "Zabbix" to "Required string" in step1?
                Try on zabbix server execute the command:
                curl http://10.153.79.110/zabbix/index.php
                and check that required string exist.
                • catchvjay
                  • May 2013
                  • 12
                  Yeah inside content it does display Zabbix SIA.
                  <!doctype html>
                  <html>
                  <head>
                  <meta http-equiv="X-UA-Compatible" content="IE=Edge"/>
                  <title>Zabbix</title>
                  <meta name="Author" content="Zabbix SIA" />
                  <meta charset="utf-8" />
                  <link rel="shortcut icon" href="images/general/zabbix.ico" />
                  <link rel="stylesheet" type="text/css" href="css.css" />
                  <link rel="stylesheet" type="text/css" href="styles/themes/originalblue/main.css" />
                  <!--[if lte IE 7]>
                  <link rel="stylesheet" type="text/css" href="styles/ie.css" />
                  <![endif]-->
                  • tchjts1
                    • May 2008
                    • 1605
                    I think I had the same issue when I included "SIA" in my required string.
                    When I just made it "Zabbix", then it worked.
                    • catchvjay
                      • May 2013
                      • 12
                      Ohh my bad..I was typing "SIA Zabbix" instead of "Zabbix SIA" that is why it was crying out.
                      Can we monitor report fetching functionality in a website via Zabbix?
                      Regards,
                      Vijay
                      • Heilig
                        • Mar 2013
                        • 366
                        Sorry, but I don't understand your question.
                        • catchvjay
                          • May 2013
                          • 12
                          Suppose we are generating reports for monthly bank statement by providing proper arguments. Can we monitor this kind report generating functionality of a website via zabbix?
                          Regards,
                          Vijay
                          • Heilig
                            • Mar 2013
                            • 366
                            You can, if information about the successful report generation is available for example, on web site (web monitoring) or in a log file (log file monitoring).
                            • catchvjay
                              • May 2013
                              • 12
                              #15
                              Thanks everyone for your time and support. I will try to test report generating functionality of my website via zabbix and update the results.
                              Regards,
                              Vijay
