String of bits - how to evaluate a single bit?
  • sovr
    • May 2013
    Hi everyboody,
    I'm using Zabbix 1.8.13 and I'm monitoring an SNMP host which returns its status as a sting of bits in which each bit carries information.
    I'd like to set triggers according to the status of each bit.
    E.g. strings received "01100010"
    trigger 1: if first bit = 1 then "memory fault"
    trigger 2: if second bit = 1 then "processor load too high"
    etc...
    could anyone please suggest how to?
    I made some Google search and found not much on it, sorry if this issue has been already discussed.
    Thanks in advance,
    sovr
  • nilie
    • May 2013
    • 16
    Is the returned value a character string or an unsigned binary ?
    • sovr
      • May 2013
      It's a character string.
      • nilie
        • May 2013
        • 16
        I haven't got the chance of doing this myself but I would give it a try like this :
        - create a character type SNMP item for the desired OID
        - create regular expressions to match the position for each one of the relevant bit (the 2nd, the 3rd etc.)
        - create a trigger using the regexp function that will test the presence of character 1 in the position dictated by the regular expression you build in previous step
        • sovr
          • May 2013
          it works great thank you!
          Unfortunately, I found out that the SNMP host actually doesn't return its status as string of bits, but as a decimal coded integer!
          Hard to find which bits are 'up' in such integer...any idea?
          Since it's a different topic, I'll open a new thread.
          Thanks a lot anyway.
          Sovr
