When I try:
I get:
The suggested workarounds don't help. How do I tell the install script to use php53 packages instead of php?
$ yum install zabbix-web-mysql
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirror.linux.duke.edu
* epel: mirror.cogentco.com
* extras: mirror.vcu.edu
* updates: mirror.anl.gov
Setting up Install Process
Resolving Dependencies
--> Running transaction check
---> Package zabbix-web-mysql.x86_64 0:2.0.6-1.el5 set to be updated
--> Processing Dependency: zabbix-web = 2.0.6-1.el5 for package: zabbix-web-mysql
---> Package zabbix-web.x86_64 0:2.0.6-1.el5 set to be updated
--> Processing Dependency: php >= 5.0 for package: zabbix-web
--> Processing Dependency: php-bcmath for package: zabbix-web
---> Package php.x86_64 0:5.1.6-39.el5_8 set to be updated
--> Processing Dependency: php-common = 5.1.6-39.el5_8 for package: php
--> Processing Dependency: php-cli = 5.1.6-39.el5_8 for package: php
---> Package php-bcmath.x86_64 0:5.1.6-39.el5_8 set to be updated
---> Package php-cli.x86_64 0:5.1.6-39.el5_8 set to be updated
---> Package php-common.x86_64 0:5.1.6-39.el5_8 set to be updated
--> Processing Conflict: php53-common conflicts php-common
--> Finished Dependency Resolution
php53-common-5.3.3-13.el5_8.x86_64 from installed has depsolving problems
--> php53-common conflicts with php-common
Error: php53-common conflicts with php-common
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
