nodewatcher % usage cpu
  • jchorier
    • May 2012
    I've got a DM setup consisting of 4 slave nodes and 1 master node.
    Only configuration is sync between nodes (no history, no events).
    but the process node watcher is always up to 99%.
    What's happens ?
    How can I trace this process ? I check the log and nothing regarding this process
    thanks
  • jchorier
    • May 2012
    up
    nobody have ideas ?
    • guaracy_tome
      • May 2013
      dm sync
      Hi Chorier,
      I have the same problem. Unsolved problem, but... take a look on link
      and this
      • Heilig
        • Mar 2013
        • 366
        Check your servers, DBs performance and decrease a frequency configuration synchronization of nodes.
        You probably know that this is an experimental feature and for better stability, please use a zabbix proxy.
