database connections after 2.0.6 upgrade
  • LenR
    • Sep 2009
    • 1011
    My server failed to start after upgrade with
    [Z3001] connection to database 'zabbixnet' failed: [1040] Too many connections
    The mysql db supports 800 connections, I reduced pollers and pingers from 200 to 100 just to get the server started. It now starts and has 588 DB connections in use. There are only about 255 zabbix_server processes on the server.
    Did something change or was I just close to the edge before?
  • Heilig
    • Mar 2013
    • 366
    Check the current settings and if necessary, increase the number of connections in the /etc/my.cnf (http://dev.mysql.com/doc/refman/5.0/...nnections.html).
    Also, please read this thread (https://www.zabbix.com/forum/showthread.php?t=13756).
