JMX : item not supported - class java.util.date
  • benbugohit
    • Feb 2013
    • 18
    i configured this item in zabbix, tested successfully with jmxterm, :
    jmx["org.apache.camel:context=satais-esb1/mainContext,type=processors,name=\"threadProcessor \"",LastExchangeCompletedTimestamp]
    But it becomes unsupported with the error :
    [l1processing:jmx["org.apache.camel:context=satais-esb1/mainContext,type=processors,name=\"threadProcessor \"",LastExchangeCompletedTimestamp]]attribute type is not primitive: %sclass java.util.Date
    i looked for "java.util.Date" in jgateway sources unsuccessfully :
    [s_dpc@satais-mcc gateway]$ pwd
    /opt/s-ais-dpc/mcc/zabbix-2.0.6/src/zabbix_java/src/com/zabbix/gateway
    [s_dpc@satais-mcc gateway]$ time (grep -nri "java.util.Date" ./* && echo OK)
    real 0m0.007s
    user 0m0.002s
    sys 0m0.002s
    That means that we can't retrieve values from attributes which type is
    java.util.Date ?
    Or how could i get value ? maybe syntax error in my item definition ?
    Thanks in advance
  • ngoswami
    • Nov 2012
    Facing the same issue
    I am also facing the same issue while trying to monitor hadoop KPIs through JMX. Is there any fix/workaround available for this issue?
    • benbugohit
      • Feb 2013
      • 18
      Originally posted by ngoswami
      Is there any fix/workaround available ?
      couldn't find none... nor answers
