ZBX_NOTSUPPORTED on timeout
  • wamsterdam
    • Apr 2013
    • 34
    When a user defined zabbix agent check times out (after 3 seconds default), zabbix_get recieves a ZBX_NOTSUPPORTED. Wouldn't it be better to recieve a ZBX_TIMEOUT? After increases the timeout in the agent config file, the user defined check works as expected. Should I submit a feature request for this?
    Wouter
