trigger dependencies - feature or bug?
  • majekw
    • Dec 2004
    Why only one trigger is sufficient to disable/hide 'master' trigger? I think that only in case when all triggers are true then 'master' should be disabled. Present behavior is ok in chain topology, but in ring there will be a problem - there will hide real problem if only one of neighbours is dead. I know that I could make 'mega' trigger with all neighbours status checked, but there is not elegant way...
