Hi .. Zabbix newbie doing some comparisons against our existing systems.
I'm comparing the agent and raw snmp output for a Linux box. It has the OS Linux SNMP template applied which then has the SNMP Processors template linked.
What I cant seem to do is create/find a graph to show me the output of the CPU util. If I check in Monitoring | Latest Data for the server then the data is being collected and graphs are available there.
But I would have expected to be able to find something via Monitoring | Graphs and navigate to the device. What I see are only the disk and network traffic graphs.
I'm sure someone will say use the agent and don't make it more difficult but there 'could' be times when SNMP is the only option ..
