php bc-math
  • johnsmith9874
    • May 2013
    • 14
    php bc-math
    I suspect that this might be a PHP issue, but can't see anything about it on other forums.
    I can install Zabbix 2.0.6 on CentOS and Ubuntu no problem. I then try to install it on a RHEL 6.3 box, and when it comes time to start the frontend-based installation, I get red errors for php-bcmath and php-mbstring.
    Trying to install them gives me ..
    # yum -y install php-bcmath
    Loaded plugins: product-id, subscription-manager
    Updating certificate-based repositories.
    Unable to read consumer identity
    Setting up Install Process
    No package php-bcmath available.
    Error: Nothing to do
    Can someone point me in the right direction?
    Thanks.
  • tchjts1
    • May 2008
    • 1605
    I installed my php-bcmath and php-mbstring through RPM packages because I think I had the same issue as you.
    Here are the packages I used...
    php-bcmath-5.3.3-14.el6_3.x86_64.rpm
    php-mbstring-5.3.3-14.el6_3.x86_64.rpm
    And the syntax to install after you download them to your RHEL box is this:
    sudo rpm -i php-bcmath-5.3.3-14.el6_3.x86_64.rpm
    sudo rpm -i php-mbstring-5.3.3-14.el6_3.x86_64.rpm
    • tchjts1
      • May 2008
      • 1605
      I actually also installed most other php modules through RPM's as well. Besides the 2 listed above, I installed these too:
      php-5.3.3-14.el6_3.x86_64.rpm
      php-mysql-5.3.3-14.el6_3.x86_64.rpm
      php-common-5.3.3-14.el6_3.x86_64.rpm
      php-xml-5.3.3-14.el6_3.x86_64.rpm
      php-cli-5.3.3-14.el6_3.x86_64.rpm
      • ZBX_beginner
        • May 2013
        Hi
        I have seen the same issues with redhat, if you would like the later versions of php-bcmath and php-mbstring. They can be found on the different redhat repo, that is not enabled by default.
        e.g.
        yum install php-bcmath php-mbstring --enablerepo=rhel-6-server-optional-rpms
        Hope that helps.
        • johnsmith9874
          • May 2013
          • 14
          Originally posted by ZBX_beginner
          Hi
          e.g.
          Hope that helps.
          Thanks for that. Unable to get the repository, though ..
          root@hostname ~# yum install php-bcmath php-mbstring --enablerepo=rhel-6-server-optional-rpms
          Error getting repository data for rhel-6-server-optional-rpms, repository not found
          • f.koch
            • Feb 2010
            • 85
            you need to login in your rhn network account and enable the optional channel, then you can install the rpms, this all works only if you had a rhn subscription and your system is registred within the rhn
            regards f.koch
            • johnsmith9874
              • May 2013
              • 14
              regards f.koch
              OK, that's going to be somewhat problematic. Is it possible to get these two RPMs from somewhere else?
              • f.koch
                • Feb 2010
                • 85
                Hm if you have no rhn subscription why not use centos?
                • johnsmith9874
                  • May 2013
                  • 14
                  Good point. OK, I have just registered with RHN. Now to find my way around... this is going to be complicated. I'm on leave as from tomorrow, and they need Zabbix installed before I go ..
                  • f.koch
                    • Feb 2010
                    • 85
                    the rpms from centos should work on rhel without problems
                    • johnsmith9874
                      • May 2013
                      • 14
                      rhn-channel -add -channel=rhel-6-server-optional
                      Usage: rhn-channel [options]
                      rhn-channel: error: no such option: -d
                      • johnsmith9874
                        • May 2013
                        • 14
                        I can't help but ask why RH has to make it so complicated.
                        I come from a Solaris background, and installing stuff was usually a matter of getting the tarball, and then ./configure, followed by make && make install.
                        Weren't RPMs and the like supposed to make it less complicated, and not more?
                        • f.koch
                          • Feb 2010
                          • 85
                          have you registred the system with rhn_register?, you only need to add the channel in the rhn, if the system is registred.
                          • johnsmith9874
                            • May 2013
                            • 14
                            Sorry, dude, the above might as well be Chinese....
                            • f.koch
                              • Feb 2010
                              • 85
                              #15
                              https://access.redhat.com/site/docum...hnreg-x86.html
                              or grab the centos rpms and be happy
