Hi all.
Brand new to Zabbix. I installed server 2.0.6 last night and put the agent on a couple of non-prod servers for test purposes. I'm using the stock Linux template for testing purposes and need help with some issues.
Problem 1: I am running the agent on Linux servers 1-4. If I look at the graphs, it shows that all servers have the same exact file system sizes, which isn't even close to correct. All servers were configured with different file system sizes and some of them have more than the standard OS filesystems. I suspect something isn't being populated correctly in the database but I'm not sure. zabbix_get wasn't installed in the installation so I can't check locally.
Problem 2: The servers that have more than just /, /boot, /var, and /opt (like /apps, /ora, et cetera) - those filesystems are not being discovered. How do I get these to be recognized in auto discovery? Some servers have up to 100 file systems. Other than NFS, they are all using ext3 within a volume group.
Problem 3: How do you install zabbix_get? I installed everything through the repository (rpm) and it isn't on the server.
Thanks in advance
-B
Thanks in advance
-B
