Problems running sytem.run item with script in (x86) folder
  • peterbnc
    • Jun 2013
    When I run an external command using system.run[] in the windows 32bit program files folder I don't get any results.
    I try to do the following;
    system.run[C:\Program Files (x86)\Zabbix Agent\myscript.vbs,nowait]
    system.run["C:\Program Files (x86)\Zabbix Agent\myscript.vbs",nowait]
    system.run[\"C:\Program Files \(x86\)\Zabbix Agent\myscript.vbs\",nowait]
    system.run[C:\test(x86)\myscript.vbs,nowait]
    that all didn't work
    if I use an folder without () it works
    system.run[C:\test test\myscript.vbs,nowait]
    Any idea how to escape these parentheses  () ?
    Using Zabbix 2.0.6 agent
    Thanx
