SNMPV3 - temporarily disabling SNMP checks
  • nicolas250
    • Jun 2013
    Someone could help me with these errors SNMPv3
    I can not run, to lower the MTU to the problem is not that
    If I do a tcpdump I see the packages, so do not know why I stopped
    thanks
    1420:20130611:150055.945 SNMP item [PD.13] on host [13] failed: first network error, wait for 15 seconds
    1419:20130611:150056.946 SNMP item [PV.13] on host [13] failed: first network error, wait for 15 seconds
    1411:20130611:150057.951 SNMP item [SD.13] on host [13] failed: first network error, wait for 15 seconds
    1408:20130611:150058.953 SNMP item [PD] on host [247] failed: first network error, wait for 15 seconds
    1409:20130611:150058.968 SNMP item [SV.13] on host [13] failed: first network error, wait for 15 seconds
    1420:20130611:150101.958 SNMP item [SD] on host [247] failed: first network error, wait for 15 seconds
    1419:20130611:150102.958 SNMP item [.1.3.6.1.2.1.2.2.1.10.3] on host [247] failed: first network error, wait for 15 seconds
    1411:20130611:150103.964 SNMP item [.1.3.6.1.2.1.2.2.1.16.3] on host [247] failed: first network error, wait for 15 seconds
    1422:20130611:150119.991 SNMP item [wan2d.13] on host [13] failed: another network error, wait for 15 seconds
    1422:20130611:150126.003 SNMP item [PD] on host [247] failed: another network error, wait for 15 seconds
    1422:20130611:150141.053 SNMP item [wan1u.13] on host [13] failed: another network error, wait for 15 seconds
    1422:20130611:150159.091 temporarily disabling SNMP checks on host [247]: host unavailable
    1408:20130611:150209.982 SNMP item [.1.3.6.1.2.1.2.2.1.16.126] on host [10.64.0.126] failed: first network error, wait for 15 seconds
    1422:20130611:150210.115 temporarily disabling SNMP checks on host [13]: host unavailable
    1422:20130611:150224.128 resuming SNMP checks on host [10.64.0.126]: connection restored
    1422:20130611:150235.337 enabling SNMP checks on host [92]: host became available
    1422:20130611:150247.374 enabling SNMP checks on host [28]: host became available
    1422:20130611:150259.564 enabling SNMP checks on host [247]: host became available
    1422:20130611:150311.745 enabling SNMP checks on host [13]: host became available
    1411:20130611:150416.552 SNMP item [wan1u.92] on host [92] failed: first network error, wait for 15 seconds
    1411:20130611:150425.576 SNMP item [SV] on host [28] failed: first network error, wait for 15 seconds
    1422:20130611:150437.812 SNMP item [wan1u.92] on host [92] failed: another network error, wait for 15 seconds
    1422:20130611:150446.833 SNMP item [SV] on host [28] failed: another network error, wait for 15 seconds
    1422:20130611:150458.854 SNMP item [PD.92] on host [92] failed: another network error, wait for 15 seconds
    1422:20130611:150507.876 SNMP item [wan2u] on host [28] failed: another network error, wait for 15 seconds
    1422:20130611:150519.918 temporarily disabling SNMP checks on host [92]: host unavailable
    1422:20130611:150531.999 temporarily disabling SNMP checks on host [28]: host unavailable
  • randydrobinson
    • Jan 2013
    I am also seeing similar errors on a zabbix proxy.
    SNMP works fine when the host is not monitored via the proxy. When the host is monitored via proxy we see the following:
    @sd-zabbixproxy ~]# tail -f /tmp/zabbix_proxy.log
    32110:20130925:041635.525 housekeeper deleted 3186 records from history (spent 0.012495 seconds)
    32004:20130925:041651.659 SNMP item [ifOperStatus.194] on host [SD1] failed: another network error, wait for 15 seconds
    31951:20130925:041652.087 Received configuration data from server. Datalen 16606
    32004:20130925:041712.666 temporarily disabling SNMP checks on host [SD1]: host unavailable
    32004:20130925:041812.739 enabling SNMP checks on host [SD1]: host became available
    31995:20130925:041821.227 SNMP item [ifOperStatus.194] on host [SD1] failed: first network error, wait for 15 seconds
    32004:20130925:041838.818 resuming SNMP checks on host [SD1]: connection restored
    31985:20130925:041851.231 SNMP item [ifOperStatus.194] on host [SD1] failed: first network error, wait for 15 seconds
    32004:20130925:041912.828 SNMP item [ifOperStatus.194] on host [SD1] failed: another network error, wait for 15 seconds
    32004:20130925:041933.843 SNMP item [ifDescr.2] on host [SD1] failed: another network error, wait for 15 seconds
    32004:20130925:041948.918 resuming SNMP checks on host [SD1]: connection restored
    31999:20130925:042003.238 SNMP item [ifDescr.1] on host [SD1] failed: first network error, wait for 15 seconds
    31964:20130925:042005.239 SNMP item [ifDescr.2] on host [SD1] failed: first network error, wait for 15 seconds
    31985:20130925:042006.239 SNMP item [ifDescr.3] on host [SD1] failed: first network error, wait for 15 seconds
    31974:20130925:042007.237 SNMP item [ifDescr.194] on host [SD1] failed: first network error, wait for 15 seconds
    32004:20130925:042028.926 SNMP item [ifDescr.2] on host [SD1] failed: another network error, wait for 15 seconds
    32004:20130925:042049.932 SNMP item [ifOperStatus.194] on host [SD1] failed: another network error, wait for 15 seconds
    32004:20130925:042110.974 temporarily disabling SNMP checks on host [SD1]: host unavailable
    32004:20130925:042211.051 enabling SNMP checks on host [SD1]: host became available
    We have a trigger condition setup like this:
    Name: {HOSTNAME} SNMP Failed
    Expression: {SD2:cpu.nodata(14400)}=1
    Description: {HOSTNAME} SNMP Failed. Check configuration, ACL.
    Please advise why the trigger condition is met when the host is monitored via proxy but not triggered when monitored from the main zabbix server.
    • nicolas250
      • Jun 2013
      now, i use external script to check snmp
      • officielmc
        • Apr 2011
        • 32
        I have also the same problem, but when i tried to get value using command line it's works. It's really strange.
        I have this problems with Juniper SSG140, and the wierd things it's I have to monitor 2 Juniper for each location (Main and backup) and everytime for one device ok no error but for the osecond one I got this error.
        item [Failover_status] on host [BJSOPS-router-back] failed: first network error, wait for 150 seconds
        item [Interface.0] on host [BJSOPS-router-back] failed: first network error, wait for 150 seconds
        item [Interface.0out] on host [BJSOPS-router-back] failed: first network error, wait for 150 seconds
        item [Interface.1] on host [BJSOPS-router-back] failed: first network error, wait for 150 seconds
        item [Interface.1out] on host [BJSOPS-router-back] failed: first network error, wait for 150 seconds
        SNMP checks on host [BJSOPS-router-back]: connection restored
        item [Failover_interface] on host [BJSOPS-router-back] failed: first network item [VPN_Status] on host [BJSOPS-router-back] failed: first network error, wait for 150 seconds
        I'm using zabbix 2.0.8 with centos 6.4 and postgresql.
        • officielmc
          • Apr 2011
          • 32
          Solved for me,
          The problem was the local-engine-id number it was the same in all my devices. So maybe you can check if you don't have the same problem.
