Host Status Unknown if UserParameters returns empty string zabbix 1.1 stable
  • marc
    • Oct 2004
    • 146
    hi all,
    while working with userparameters (referenz http://www.zabbix.com/forum/showthread.php?t=3144) i encountert a serious bug. i added a new case in UserParameter Script, cmta.sendmailmqueue[all] and added it to template. Of course i distributed the changed script to all hosts linked with the template but at this task i forgot one single host.
    This host became Status 2 but no alarm or trigger was generated or got active.
    unreachable {Template.name:status.min(120)}=2 is defined of course. Pls recheck but i guess zabbix is handling something wrong if script returns empty string. in this case the item should be gone unsupported but the host should be still active and other checks have to work. iam not sure if its just in the case of usig variables in UserParameter scripts or if its a templating issue because in the past without both conditions, items became unsupported like it supposed to be. i would debug myself but at the moment iam at heavy working load.
    regards,
    marc
  • stever
    • Jun 2006
    • 36
    I agree that this shouldn't be the case, and zabbix should set the item to unsupported automatically.
    However, it is mentioned in the example config file:
    # Format: UserParameter=<key>,<shell command>
    # Note that shell command must not return empty string or EOL only
    I created wrapper scripts for my user parameters that return a '0' if nothing is returned by the command.
