Zabbix Child node dashboard not updating
  • Zeeshan
    • Apr 2013
    • 18
    hi guys,
    i have setup a distributed setup for zabbix with one master node and one child. the dashboard for the master node works ok but the child node doesnt display anything, although i can add hosts to the child node through the master node.
    i had a look in the logs and i am getting the following errors:
    On Child Node:
    20458:20130613:132039.992 NOT OK
    20458:20130613:132049.127 NODE 2: Sending history_sync of node 2 to node 1 datalen 111
    20458:20130613:132049.234 NODE 2: Sending history_uint_sync of node 2 to node 1 datalen 353
    20458:20130613:132049.439 NODE 2: Sending events of node 2 to node 1 datalen 31061
    20458:20130613:132049.499 NOT OK
    On Master Node:
    [Z3005] query failed: [1452] Cannot add or update a child row: a foreign key constraint fails (`zabbix`.`acknowledges`, CONSTRAINT `c_acknowledges_2` FOREIGN KEY (`eventid`) REFERENCES `events` (`eventid`) ON DELETE CASCADE) [insert into acknowledges (acknowledgeid,userid,eventid,clock,message) values (200200000000001,200200000000001,200000000000016,1 371117179,'
    i have had a look on the forums and have already performed the following steps:
    * 1. Stop Master node
    * 2. Execute on NODEx (not MASTER):
    *delete from node_cksum;
    *delete from node_configlog;
    * 3. Start Master node
    and
    truncate table history_sync;
    truncate table history_uint_sync;
    truncate table history_str_sync;
    truncate table node_cksum;
    but nothing seems to work..... Please help
    regards
    Z
  • nail
    • Jun 2012
    • 32
    I have probably the same issue
    It shows alerts if I open child-node dashboad directly, but if I open it through master-node I see what displayed on screenshot.
    Issues count (highlighted) is the same on both.
    Some alerts are shown through master-node, but have incorrect "Last change".
    • Zeeshan
      • Apr 2013
      • 18
      I have tried this, it has hopefully sorted the problem i am still testing though.
      login to the client node and do the following:
      SELECT count(*) FROM events LEFT JOIN triggers ON triggers.triggerid=events.objectid WHERE events.source='0' AND triggers.triggerid is null;
      DELETE from events WHERE source='0' AND objectid NOT IN (SELECT triggerid from triggers);
      according to what i have read, this issue is caused by triggers which have 0 source id if you remove these triggers it show be OK. The above mysql commands do this.
      Good Luck!
      Z
      • nail
        • Jun 2012
        • 32
        Good Luck!
        Z
        unfortunately it didn't helped. some triggers still are displayed only on child dashboard.
        • eterjack
          • Mar 2012
          • 60
          Thx for this:
          Worked
          • alexfear
            • Sep 2013
            Good Luck!
            Z
            Many thanks for this solution, it fixed my issue with empty dashboard of child node!
