I'm trying to upgrade our Zabbix 1.8.8 to 2.0.6 but somehow the DB upgrade script fails every time.
I'm wondering something has happened to our DB, as it seems it is missing quite many needed tables like users etc.
Example output:
Any ideas how to continue? I know that the schema.sql does try to create the necessary tables but I didn't know it was needed to be imported before the patch.sql.
Thank you in advance!
Best Regards,
-Pasi
Example output:
./upgrade -uroot -pxxxxxx -Dzabbix WARNING: backup your database before performing upgrade This is an UNSUPPORTED Zabbix upgrade script from 1.8 to 2.0 for MySQL It does the following things: 1. Updates indexes that might require changes; 2. Patches the database from 1.8 schema to 2.0 schema; 3. Adds 'Disabled' and 'Debug' usergroup if any missing; 4. Checks for hosts not belonging to any group and adds them to one if any found. Usage: pass required MySQL parameters to this script (like database, user, password etc). Continue ? (y/n) y Patching the database ERROR 1146 (42S02) at line 4: Table 'zabbix.users' doesn't exist Failed to patch Zabbix database. Restore from backup
Best Regards,
-Pasi
