Error getpeername
  • tincan
    • Jun 2006
    Error getpeername
    I've compiles zabbix server 1.1 on redhat ES4. Everything seems to be working ok server side.
    I've installed a zabbix agent on Windows 2003. It works perfectly.
    However I've compiled the zabbix agent 1.1 on another redat ES3, it works for a couple of minutes then it stops working with this error:
    Connection reset by peer.
    The log files for the zabbix agent:
    004084:20060622:112020 Connection from [10.3.5.10]. Allowed servers [10.3.5.10]
    004084:20060622:112020 Before read()
    004084:20060622:112020 After read() 2 [21]
    004084:20060622:112020 Got line:net.tcp.service[ssh]
    004084:20060622:112020 Sending back:1
    004085:20060622:112020 In check_security()
    004085:20060622:112020 Connection from [10.3.5.10]. Allowed servers [10.3.5.10]
    004085:20060622:112020 Before read()
    004085:20060622:112020 After read() 2 [20]
    004085:20060622:112020 Got line:vfs.fs.size[/,used]
    004085:20060622:112020 Sending back:3035952
    004082:20060622:112020 In check_security()
    004082:20060622:112020 Connection from [10.3.5.10]. Allowed servers [10.3.5.10]
    004082:20060622:112020 Before read()
    004082:20060622:112020 After read() 2 [23]
    004082:20060622:112020 Got line:vm.memory.size[shared]
    004082:20060622:112020 Sending back:0
    004083:20060622:112020 In check_security()
    004083:20060622:112020 Connection from [10.3.5.10]. Allowed servers [10.3.5.10]
    004083:20060622:112020 Before read()
    004083:20060622:112020 After read() 2 [22]
    004083:20060622:112020 Got line:vm.memory.size[total]
    004083:20060622:112020 Sending back:4192722944
    004084:20060622:112020 In check_security()
    004084:20060622:112020 read() failed.
    004084:20060622:112020 After read() 1
    004085:20060622:112038 In check_security()
    004085:20060622:112038 Connection from [10.3.5.10]. Allowed servers [10.3.5.10]
    004085:20060622:112038 Before read()
    004085:20060622:112038 read() failed.
    004085:20060622:112038 After read() 1
    004082:20060622:112053 In check_security()
    004082:20060622:112053 Error getpeername [Transport endpoint is not connected]
    004082:20060622:112053 Connection rejected
    004083:20060622:112108 In check_security()
    004083:20060622:112108 Error getpeername [Transport endpoint is not connected]
    004083:20060622:112108 Connection rejected
    004084:20060622:112208 In check_security()
    004084:20060622:112208 Connection from [10.3.5.10]. Allowed servers [10.3.5.10]
    004084:20060622:112208 Before read()
    004084:20060622:112208 read() failed.
    004084:20060622:112208 After read() 1
    004085:20060622:112308 In check_security()
    004085:20060622:112308 Connection from [10.3.5.10]. Allowed servers [10.3.5.10]
    004085:20060622:112308 Before read()
    004085:20060622:112308 read() failed.
    004085:20060622:112308 After read() 1
    004082:20060622:112408 In check_security()
    004082:20060622:112408 Error getpeername [Transport endpoint is not connected]
    004082:20060622:112408 Connection rejected
    004083:20060622:112508 In check_security()
    004083:20060622:112508 Connection from [10.3.5.10]. Allowed servers [10.3.5.10]
    004083:20060622:112508 Before read()
    004083:20060622:112508 read() failed.
    004083:20060622:112508 After read() 1
    004084:20060622:112608 In check_security()
    004084:20060622:112608 Connection from [10.3.5.10]. Allowed servers [10.3.5.10]
    004084:20060622:112608 Before read()
    004084:20060622:112608 read() failed.
    004084:20060622:112608 After read() 1
    The zabbix server log files:
    006714:20060622:112500 Enabling host [cmsweb.idrc.ca]
    006714:20060622:112500 Connection reset by peer.
    006714:20060622:112500 Host [cmsweb.idrc.ca]: first network error, wait for 15 seconds
    006714:20060622:112521 Connection reset by peer.
    006714:20060622:112521 Host [cmsweb.idrc.ca]: first network error, wait for 15 seconds
    006713:20060622:112539 Connection reset by peer.
    006713:20060622:112539 Host [cmsweb.idrc.ca]: another network error, wait for 15 seconds
    006713:20060622:112554 Connection reset by peer.
    006713:20060622:112554 Host [cmsweb.idrc.ca]: another network error, wait for 15 seconds
    006713:20060622:112609 Connection reset by peer.
    006713:20060622:112609 Host [cmsweb.idrc.ca] will be checked after 60 seconds
    006713:20060622:112709 Connection reset by peer.
    006713:20060622:112709 Host [cmsweb.idrc.ca] will be checked after 60 seconds
    006713:20060622:112809 Connection reset by peer.
    006713:20060622:112809 Host [cmsweb.idrc.ca] will be checked after 60 seconds
    006713:20060622:112909 Connection reset by peer.
    006713:20060622:112909 Host [cmsweb.idrc.ca] will be checked after 60 seconds
    006713:20060622:113009 Connection reset by peer.
    006713:20060622:113009 Host [cmsweb.idrc.ca] will be checked after 60 seconds
    006713:20060622:113109 Connection reset by peer.
    006713:20060622:113109 Host [cmsweb.idrc.ca] will be checked after 60 seconds
    006713:20060622:113209 Connection reset by peer.
    006713:20060622:113209 Host [cmsweb.idrc.ca] will be checked after 60 seconds
    006713:20060622:113309 Connection reset by peer.
    006713:20060622:113309 Host [cmsweb.idrc.ca] will be checked after 60 seconds
    Any ideas???
    Thanks.
  • tincan
    • Jun 2006
    OK... I tried the zabbix 1.1 agent on another Redhat ES4... and the agent is working fine. So the issue must be with something on Redhat ES3.
    Do I need to recompile with a switch of some sort?
