Hi All,
I have been having several issues with zabbix not working well with the SNMP agent. I have over 900 hosts, which are monitored with a ping check template, all of the servers have the zabbix agent installed and seem to be working, but when I tried to use the SNMP templates to monitor/graph switches, routers, etc. I run into the problems. I have 7 switches monitored via SNMP and seems to work fine. I tried to add more and was immediately bombarded with errors in the logs. See clip below:
SNMP item [XXX]] on host [XXX] failed: first network error, wait for 15 seconds
resuming SNMP checks on host [XXXV]: connection restored
Basically it's a loop, it would fail then restore over and over. It also affected the 7 that seemed to be working before. I removed the additional hosts and it went back to normal. I thought maybe I added too many at once, but I tried again adding only 5 more and it was nuts again. Any suggestions would be greatly appreciated .
Thanks,
Steve
Thanks,
Steve
