proxy can not work well
  • lovememe
    • Jun 2013
    Hi all
    When i add a proxy through web console:
    Administration --> DM --> create proxy
    then enter the "Proxy name" as "proxynj", and other keep the default
    I have got a lot errors in zabbix_server.log like below:
    23039:20130621:115506.773 Heartbeat from active proxy on [10.111.0.17] failed: proxy [proxynj] not found
    when turn the log to debug:
    16089:20130621:141617.732 In collect_selfmon_stats()
     16089:20130621:141617.733 End of collect_selfmon_stats()
     16089:20130621:141617.733 sleeping for 1 seconds
     16075:20130621:141618.015 Trapper got [] len 0
     16089:20130621:141618.733 In collect_selfmon_stats()
     16089:20130621:141618.733 End of collect_selfmon_stats()
     16089:20130621:141618.733 sleeping for 1 seconds
     16087:20130621:141618.863 In process_escalations()
     16087:20130621:141618.863 query [txnlev:0] [select escalationid,actionid,triggerid,eventid,r_eventid,esc_step,status,nextcheck from escalations where 1=1 and escalationid between 100000000000000 and 199999999999999 order by actionid,triggerid,escalationid]
     16087:20130621:141618.865 End of process_escalations()
     16087:20130621:141618.865 escalator #1 spent 0.002681 seconds while processing escalations
     16087:20130621:141618.865 sleeping for 3 seconds
     16076:20130621:141619.142 In get_pinger_hosts()
     16076:20130621:141619.142 In DCconfig_get_poller_items() poller_type:3
     16076:20130621:141619.142 End of DCconfig_get_poller_items():0
     16076:20130621:141619.142 End of get_pinger_hosts():0
     16076:20130621:141619.142 In process_pinger_hosts()
     16076:20130621:141619.142 End of process_pinger_hosts()
     16076:20130621:141619.142 icmp pinger #1 spent 0.000394 seconds while processing 0 items
     16076:20130621:141619.142 In DCconfig_get_poller_nextcheck() poller_type:3
     16076:20130621:141619.142 End of DCconfig_get_poller_nextcheck():-1
     16076:20130621:141619.142 sleeping for 5 seconds
     16075:20130621:141619.360 Trapper got [{
    	"request":"proxy config",
    	"host":"proxynj"}] len 47
     16075:20130621:141619.360 In send_proxyconfig()
     16075:20130621:141619.360 query [txnlev:0] [select hostid from hosts where host='proxynj' and status in (5) and hostid between 100000000000000 and 199999999999999]
     16075:20130621:141619.365 Proxy config request from active proxy on [10.111.0.17] failed: proxy [proxynj] not found
     16073:20130621:141619.381 Trapper got [{
    	"request":"proxy heartbeat",
    	"host":"proxynj"}] len 50
     16073:20130621:141619.381 In recv_proxy_heartbeat()
    [COLOR="red"] [B]16073:20130621:141619.381 query [txnlev:0] [select hostid from hosts where host='proxynj' and status in (5) and hostid between 100000000000000 and 199999999999999]
     16073:20130621:141619.385 Heartbeat from active proxy on [10.111.0.17] failed: proxy [proxynj] not found[/B][/COLOR]
     16065:20130621:141619.639 In get_values()
     16088:20130621:141619.639 In process_proxy()
     16065:20130621:141619.639 In DCconfig_get_poller_items() poller_type:0
     16088:20130621:141619.639 In DCconfig_get_proxypoller_hosts()
     16065:20130621:141619.639 End of DCconfig_get_poller_items():0
     16088:20130621:141619.639 End of DCconfig_get_proxypoller_hosts():0
     16065:20130621:141619.639 End of get_values():0
     16088:20130621:141619.639 End of process_proxy()
     16065:20130621:141619.639 poller #1 spent 0.000270 seconds while updating 0 values
     16088:20130621:141619.639 proxy poller #1 spent 0.000328 seconds while processing   0 proxies
     16065:20130621:141619.639 In DCconfig_get_poller_nextcheck() poller_type:0
     16088:20130621:141619.639 In DCconfig_get_proxypoller_nextcheck()
     16065:20130621:141619.639 End of DCconfig_get_poller_nextcheck():-1
     16088:20130621:141619.639 End of DCconfig_get_proxypoller_nextcheck():-1
     16065:20130621:141619.639 sleeping for 5 seconds
     16088:20130621:141619.639 sleeping for 5 seconds
     16084:20130621:141619.639 Syncing ...
     16084:20130621:141619.639 In DCsync_history() history_first:0 history_num:0
     16084:20130621:141619.639 history syncer #2 spent 0.000042 seconds while processing 0 items
     16084:20130621:141619.639 sleeping for 5 seconds
     16069:20130621:141619.639 In get_values()
     16069:20130621:141619.639 In DCconfig_get_poller_items() poller_type:0
     16069:20130621:141619.639 End of DCconfig_get_poller_items():0
     16069:20130621:141619.639 End of get_values():0
     16069:20130621:141619.639 poller #5 spent 0.000188 seconds while updating 0 values
     16069:20130621:141619.639 In DCconfig_get_poller_nextcheck() poller_type:0
     16069:20130621:141619.639 End of DCconfig_get_poller_nextcheck():-1
     16069:20130621:141619.640 sleeping for 5 seconds
     16085:20130621:141619.661 Syncing ...
     16085:20130621:141619.661 In DCsync_history() history_first:0 history_num:0
     16085:20130621:141619.661 history syncer #3 spent 0.000044 seconds while processing 0 items
     16085:20130621:141619.661 sleeping for 5 seconds
     16067:20130621:141619.674 In get_values()
     16067:20130621:141619.674 In DCconfig_get_poller_items() poller_type:0
     16067:20130621:141619.674 End of DCconfig_get_poller_items():0
     16067:20130621:141619.674 End of get_values():0
    the zabbix version:
    [root@my2950 zabbix-2.0.7rc1]# /usr/local/zabbix/sbin/zabbix_server --version
    Zabbix server v2.0.7rc1 (revision 36371) (22 April 2013)
    Compilation time: Jun 21 2013 10:18:48
    configuration option:
    ./configure --prefix=/usr/local/zabbix --sysconfdir=/etc/zabbix --docdir=/usr/share/doc --enable-server --with-oracle=/usr/lib/oracle/11.2/client64 --with-net-snmp --with-jabber --with-libcurl
    the log:
    [root@my2950 zabbix-2.0.7rc1]# more /var/log/zabbix/zabbix_server.log
     20200:20130621:154534.324 Starting Zabbix Server. Zabbix 2.0.7rc1 (revision 36371).
     20200:20130621:154534.324 ****** Enabled features ******
     20200:20130621:154534.324 SNMP monitoring:           YES
     20200:20130621:154534.324 IPMI monitoring:            NO
     20200:20130621:154534.324 WEB monitoring:            YES
     20200:20130621:154534.324 Jabber notifications:      YES
     20200:20130621:154534.324 Ez Texting notifications:  YES
     20200:20130621:154534.324 ODBC:                       NO
     20200:20130621:154534.324 SSH2 support:               NO
     20200:20130621:154534.324 IPv6 support:               NO
     20200:20130621:154534.324 ******************************
     20200:20130621:154534.324 NodeID:                      1
     20200:20130621:154534.988 no records in table 'config'
     20200:20130621:154535.226 no records in table 'config'
     20201:20130621:154535.254 server #1 started [configuration syncer #1]
     20202:20130621:154535.254 server #2 started [db watchdog #1]
     20211:20130621:154535.261 server #11 started [trapper #3]
     20209:20130621:154535.264 server #9 started [trapper #1]
     20212:20130621:154535.275 server #12 started [trapper #4]
     20213:20130621:154535.277 server #13 started [trapper #5]
     20214:20130621:154535.278 server #14 started [icmp pinger #1]
     20215:20130621:154535.280 server #15 started [alerter #1]
     20210:20130621:154535.284 server #10 started [trapper #2]
     20218:20130621:154535.297 server #18 started [node watcher #1]
     20217:20130621:154535.298 server #17 started [timer #1]
     20216:20130621:154535.300 server #16 started [housekeeper #1]
     20216:20130621:154535.300 executing housekeeper
     20219:20130621:154535.301 server #19 started [http poller #1]
     20223:20130621:154535.309 server #23 started [history syncer #3]
     20221:20130621:154535.315 server #21 started [history syncer #1]
     20222:20130621:154535.318 server #22 started [history syncer #2]
     20224:20130621:154535.322 server #24 started [history syncer #4]
     20200:20130621:154535.332 server #0 started [main process]
     20226:20130621:154535.340 server #26 started [proxy poller #1]
     20227:20130621:154535.343 server #27 started [self-monitoring #1]
     20225:20130621:154535.351 server #25 started [escalator #1]
     20208:20130621:154535.490 server #8 started [unreachable poller #1]
    the database is oracle 11G r2, in the database:
    SQL> select hostid from hosts where host='proxynj';
    HOSTID
    10095
    SQL>
    but there is nothing when add "between 100000000000000 and 199999999999999"
    it looks like this caused the proxy can not work well.
    How can i fix this problem?
    in the proxy machine, there are a lot errers like this blow:
    2044:20130621:195040.659 Heartbeat message failed
      2044:20130621:195141.995 Heartbeat message failed
      2044:20130621:195242.287 Heartbeat message failed
      2044:20130621:195340.552 Heartbeat message failed
    2043:20130621:194541.852 Cannot obtain configuration data from server. Proxy host name might not be matching that on the server.
    below is my proxy configuration information:
    [root@proxynj ~]# cd /etc/zabbix/
    [root@proxynj zabbix]# hostname
    proxynj
    [root@proxynj zabbix]# grep ${HOSTNAME} *
    zabbix_agentd.conf:Hostname=proxynj
    zabbix_proxy.conf:Hostname=proxynj
    zabbix_proxy.conf:HostnameItem=proxynj
    thanks.
  • tchjts1
    • May 2008
    • 1605
    1. I would question the use of 2.0.7rc1... it is only a release candidate!
    2. The use of Hostname= and HostnameItem= is one or the other, not both. I don't know if that is playing a part in the issue or not, but you should fix that to rule it out.
    It says HostnameItem is ignored if Hostname= is used... but still...
    ### Option: Hostname
    #       Unique, case sensitive Proxy name. Make sure the Proxy name is known to the server!
    #       Value is acquired from HostnameItem if undefined.
    # Mandatory: no
    # Default:
    # Hostname=
    Hostname=My Proxy name
    ### Option: HostnameItem
    #       Item used for generating Hostname if it is undefined.
    #       Ignored if Hostname is defined.
    # Mandatory: no
    # Default:
    # HostnameItem=system.hostname
    • lovememe
      • Jun 2013
      # Mandatory: no
      # Default:
      # Hostname=
      # Mandatory: no
      # Default:
      thanks for reply.
      For 2:
      I have try to set single Hostname && both Hostname and HostnameItem ,
      it all comes out to the same thing.
      For1:
      in the first time, i install zabbix 2.0.6 through yum use zabbix repo(zabbix-server-oracle was compiled by myself), but it will cause some problems when add TEMPLATES or Graphs.
      zabbix 2.0.7rc1 is work well with oracle except proxy.
