zabbix_agentd is dying
  • zeratul
    • Jun 2006
    Hi
    I installed the server on a CentOS 4.2 machine and is working well, but I have problems with zabbix_agentd which are dying on various other servers where I installed this software. There is no specific hour or event when this is happening (I tried to make a connection between the agent death and a cron job or something, but they are dying randomly).
    The list of servers includes Fedora Core 2 and 4, CentOS 4.2 and Mandriva 2006. I tried the agents from 1.1 stable, 1.1 beta 11 and 1.1 beta 12. The servers are working well - they are production machines - and I have no reason to suspect something wrong on this side.
    The agents are dying in 2 ways:
    - the zabbix_agentd processes just vanish without any error in log files (btw, why /tmp/zabbix_agentd.log is always empty even with DebugLevel=4 in /etc/zabbix/zabbix_agentd.conf ?)
    - the zabbix_agentd processes still exist, but the server can't get any data from them, and the syslog file is showing "*** glibc detected *** double free or corruption". I must use "killall -9 ..." to get rid of the precesses, then I must wait 1-2 minutes until I can start again zabbix_agentd. I found something related to "export MALLOC_CHECK_=0" but it does not seems to help in any way.
    I even tried a precompiled binary for debian. It's working fine, from the data collecting point of view, but is dying like the rest.
    Maybe there is something obvious that I'm missing and I'm doing wrong on all servers. Anyone has any idea ? Or, someone who has a running zabbix_agentd compiled on/for a system like the above systems, can send me the binary?
    Thank you.
    Daniel
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It seems that there is a problem with ZABBIX agent when doing proc.mem under Linux. We even managed to reproduce the problem once or twice but still didn't see why it happens.
    Give us some time to have it fixed.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • zeratul
      • Jun 2006
      Thank you for your answer. Until you'll find a solution, there is an option for me to disable the item "proc.mem" ?
      Daniel
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        You may disable monitoring of all items having key proc.mem[...]. Let me know if it makes agent stay alive.
        Alexei Vladishev
        My Twitter
        • zeratul
          • Jun 2006
          You're right. Since I got your answer, until today, no agent died anymore, after I disabled all items having key proc.mem[].
          I found the reason for not having any log in /tmp/zabbix_agentd.log . The file is created by zabbix_agentd startup, with user.group=root.root, with permission 644 :
          [root@server tmp]# ls -l /tmp/zabbix_agentd.log
          -rw-r--r-- 1 root root 0 Jun 26 17:54 /tmp/zabbix_agentd.log
          Zabbix_agentd, is trying to write in this file as user zabbix and this fails. So, I changed the owner of the file and now I have also logs for the agent.
          Daniel
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            Thanks for your post. We are still trying to understand why it crashes while evaluating proc.mem. No progress so far.
            Alexei Vladishev
            My Twitter
            • bgd
              • May 2006
              • 9
              The problem is probably in common.c->process()
              Hi Alexei,
              I've had this problem as well. The last lines in the Agent's log file are:
              032351:20060627:110001 Got lineroc.mem[zabbix_agentd]
              032350:20060627:110001 One child process died. Exiting ...
              032352:20060627:110001 Got signal. Exiting ...
              032353:20060627:110001 Got signal. Exiting ...
              "Got line:" is probably in the zabbix_agentd.c -> process_child() function, so the problem is most likely in common.c -> process() (the function called immediately after the 'Got line' entry in the log file).
              Hope this helps,
              bogdan
              • Alexei
                Founder, CEO
                • Sep 2004
                • 5654
                Fixed, finally we found what's wrong
                See http://www.zabbix.com/forum/showthread.php?t=3317
                Alexei Vladishev
                My Twitter
