Status of triggers used in screen
  • Scheffie
    • Apr 2005
    • 15
    I've created a screen with a Status of Triggers section. It is working wel.. triggers come and go as they should, but other then in the real triggers page (Monitoring > triggers) the {item.value} text in the issue descriptions are not changing during the time a trigger is active.
    So for example, i've made a trigger for the amount of computers that have wsus updates pending <> 0. This trigger got fired with an initial value of 4.
    Now, a day later 2 more pc's updated their wsus status and now the trigger description on the Monitoring > Triggers page says 6, but the status of triggers section on my screen still says 4 (even after refresh).
    Is their a fix for this?
    Greetings,
    Bart
  • eskytthe
    • May 2011
    • 363
    Try item.lastvalue instead.
    (The macro documentation could maybe be a little more clear)
    BR
    Erik
