Can't create trigger in template
  • Jaroslav_Safranek
    • Jul 2013
    I'am using Zabbix in ver. 2.0.6 on MySQL.
    I have problems when i try make new trigger for my template Ping.
    Normaly I click on New trigger and type Name and Expressinon (first screen), but when Save no result, only this second screen. Trigger isn't saved.
    Same error is when I need change expressinon on normaly function trigger.
    On host I can trigger change or create normaly.
    Template Ping I was create about half year in past and it worked normaly.
    Is there any error on Zabbix frontend in this point?
    Thanks for replies.
