I just updated by Zabbix install from 1.8 to 2.0. I'm running a CentOS 6.4 VPS server using the Zabbix packages in EPEL. For the upgrade I shutdown both the agent and server before hand, then removed the 1.8 packages, installed the 2.0 packages then ran the patch.sql for the upgrade of the MySQL database which completed without problems. Everything appeared to work OK until I saw the following PHP errors on the screens page
Not sure what to make of it, I couldn't find anything useful, I tried re-running the images.sql file on my DB but this hasn't changed anything.
Any help would be great, this was working on 1.8!
Thanks,
James
Thanks,
James
