I created a script for monitoring PostgreSQL server on windows. The script is implemented in VBScript and destined to be run with cscript.exe. Source code and installation instruction are here: https://github.com/akurdyukov/Zabbix...ows-postgresql
The script works perfectly when run from command line. But I experience problems with running script under zabbix agent. It seems that script aborts after "Set objExec = objShell.Exec(strExe)" line that invokes psql.exe. Unfortunatelly, there's no useful info for the problem in logs at level 4.
Can you help me with ideas for debugging the problem?
Is there any way to understand what goes wrong with cscript under zabbix agent?
Thanks in advance!
Thanks in advance!
