Install / upgrade lib-curl in Zabbix 2.0.6 server
  • rmsys
    • Jul 2013
    • 13
    Hey guys,
    I found that after compiling the server does not include the option "--with-libcurl".
    Is it possible to install this library separately or make a "rebuild" without further damage?
  • tchjts1
    • May 2008
    • 1605
    I would think that you can simply run "make clean" in your compile directory, recompile with libcurl included with all your other compile options, and then replace your old binary with your new one.
    • Pada
      • Apr 2012
      • 236
      Also take note that the configure arguments are stored near the top of config.log
      Unfortunately that log is replaced every time you run ./configure
      I'd guess that you can just run following to get the libcurl into your server:
      ./configure <args>
      make install
      service zabbix-server restart
      It should keep your server configuration files in tact.
