Log Trigger doesn´t clear with no new data
  • hupp
    • Feb 2008
    • 23
    I have a log item which collects the hole logfile (Zabbix agent active).
    log[/var/log/test.log,,,100,skip]
    My Trigger expression is: {zbxsrv01:log[/var/log/test.log,,,100,skip].iregexp("error",30)}=1
    This works as long as new data in the logfile is collected. But if no new data is collected, the trigger stays on problem and doesn´t clear.
    My idea was to work with the nodata function, so my trigger looks like this now:
    {zbxsrv01:log[/var/log/test.log,,,100,skip].iregexp("error",30)}=1&{zbxsrv01:log[/var/log/test.log,,,100,skip].nodata(30)}=0
    But after the specified 30 seconds I get following error on the dashboard at this trigger in the Info field:
    Evaluation failed for function: {zbxsrv01:log[/var/log/test.log,,,100,skip].str(Error,30)}
    The timeperiod on the item above is my test, the production item has a higher value.
    Can someone help me please?
    My zabbix version is 2.0.6
